Passive Radiator
stephen0630
I have a question and or a concern about the passive radiators on my SDA 1C's. Today I installed Mortite in the place of the factory gaskets and replaced a passive radiator. After I was done swapping out the bad radiator I noticed that there was a metal bolt on the old passive radiator. The one that I had just put in didn't have one. Do I need to remove the radiator and put the bolt from the old one in it or just leave it alone?
Onkyo TX-SR703
Carver M-4.0t
Polk SDA-1C's
Polk Monitor 4
Sony SS-B1000
Infinity Entra Sub
Sony SCD-CE595
Sanyo TP 727 Turntable
Magnavox Blu-ray Player NB500MG1F
Phillips 42" LCD 1080p
Xbox 360
Wii
Carver M-4.0t
Polk SDA-1C's
Polk Monitor 4
Sony SS-B1000
Infinity Entra Sub
Sony SCD-CE595
Xbox 360
Wii
If you are talking about the silver weight on the back side, Yes I would put it on your new one..
Yes I am referring to the weight. I wasn't sure if it would effect the sound.Onkyo TX-SR703
Carver M-4.0t
Polk SDA-1C's
Polk Monitor 4
Sony SS-B1000
Infinity Entra Sub
Sony SCD-CE595
Xbox 360
Wii
