ortofon p- stylus
mhmacw
what are the stylus options for the p style of cartrige? ive looked at the needle doctor but dont fully understand whats going on with phono. i have an ortofon 14 that needs replaced but im not sure which models i can replace it with. do i have to stick to the 14?
sorry i posted this in the wrong section.
Post edited by mhmacw on
You can get http://www.needledoctor.com/Ortofon-14-Stylus. Yes, according to the chart there, if you stick with the 14 cart, you will have to stick to a 14 stylus.
Or you can look at http://www.needledoctor.com/Online-Store/P-Mount-Cartridges, which is all their p-mount style carts.
It might help if you posted what type of table and arm you have, and what you listen to. Also, what you like and don't like about the current cart/stylus would be helpful in trying to make recommendations.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
