ortofon p- stylus
mhmacw
mhmacw Posts: 832
edited March 2010 in DIY, Mods & Tweaks
what are the stylus options for the p style of cartrige? ive looked at the needle doctor but dont fully understand whats going on with phono. i have an ortofon 14 that needs replaced but im not sure which models i can replace it with. do i have to stick to the 14?
sorry i posted this in the wrong section.
Post edited by mhmacw on
  • quadzilla
    quadzilla Posts: 1,543
    edited March 2010
    You can get http://www.needledoctor.com/Ortofon-14-Stylus. Yes, according to the chart there, if you stick with the 14 cart, you will have to stick to a 14 stylus.
    Or you can look at http://www.needledoctor.com/Online-Store/P-Mount-Cartridges, which is all their p-mount style carts.
    It might help if you posted what type of table and arm you have, and what you listen to. Also, what you like and don't like about the current cart/stylus would be helpful in trying to make recommendations.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
