Speaker connections
coomikaze
I just bought some Monitor 30's and Monitor 60's and my question is why is there 4 wire connections on them. Kind of a easy question but I'm just not sure.
Post edited by coomikaze on
For biamping purposes. You can use different amps to power the highs/lows separately.
Welcome!I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
So I am guessing it doesn't matter which ones I plug the wires into other than Negative to Negative and Positive to Positive.
Right, those plates will take care of the dirty work.
That said, if you want a nice cheap improvement in sound, replace those plates with some speaker wire, and just use wire to jump both.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thanks for the help.
I had great success with Radio Shack 12 guage pure stranded copper wire using it as jumpers. Very inexpensive.
Looks like the guys took care of ya coomikaze, hope you get it all hooked up and sounding great. Welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
