The best improvement yet less than $100
ben62670
ben62670 Posts: 15,969
Well less than $100 and 2 hours later I installed a 50amp sub panel and 2 duplex outlets for my system. The run from the sub panel is only 6 feet from the sub panel of 12/3. The old wiring ran the kitchen, dining room, living room, and air handler. Everything is so much better. Smoother, better dynamics, sharp(clean) symbol hits, and sweet mids. I can't stress enough what a clean source of power can do for you. With electricity it isn't so much about the available power. I never tripped a breaker. It is about cutting out all the noise. With standard wiring you have a junction from light switch to outlet to outlet to switch box and so on. I have been putting this off for a long time and it really needed to be done. Before the mids and highs were grainy, but I blamed it on the Adcom's and my tubes. The tubes really appreciate the clean power the most, and drove me to do the sub pannel install. BTW I stole the range wire for the sub panel. The house was setup for gas or electric stove. I like to cook on gas anyway.
Ben
Ben
Post edited by ben62670 on
    Tony M Posts: 11,621
    edited March 2010
    I've been reading about cutting stuff out of the circuit. Not too easy for most but sure is nice to do it if you can, and when a lightning storm comes around ,it would be easy to cut just the power to the system at a breaker.
  • jimmydep
    jimmydep Posts: 1,305
    edited March 2010
    I agree with Sal, In a storm the only way to protect your equipment is to completely disconnect it from the house wiring, i.e. pull the plug
  • ben62670
    edited March 2010
    Yeah the electricity can travel up the ground even if the breaker is off.
    Ben
    Toolfan66 Posts: 18,057
    edited March 2010
    I would love to get this done.
    Enjoy bro..
  • sandworms
    sandworms Posts: 1,043
    edited March 2010
    Any pics ben?
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • RCFGuitars
    RCFGuitars Posts: 159
    edited March 2010
    You are absolutely right Ben. I had this done a couple of months ago, and the improvement was huge. You're also spot on about tubes really needing clean, stable power to sound their best. I only gig with tube amps, and I've been lugging around power conditioner/line regulators for years for that very reason. Enjoy the upgrade :)
    Primary System
    Polk Audio SDA SRS 2.3TL (RDO198,Sonicap/Dayton/Mills,CardasCCGR,Mye Spikes,DynamatX,Driver Rings,Ben's IC,Bi-Wired)
    Polk Audio CSiA4 x2 (C)
    Polk Audio FXiA6 (S)
    Polk Audio RTiA3 (RS)
    Polk Audio FXiA4 (FX)
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Technics/KAB SL-1210M5G w/ Denon DL-160
    Parasound Halo P7
    OPPO BDP-83
    Panasonic TC-P65V10 65" Plasma
  • jinjuku
    jinjuku Posts: 1,523
    edited March 2010
    Lasareath wrote: »
    Some people say that is not enough, that lightning will jump across an open breaker.
    What I do is I unplug my system and I move the plug as far as I can from the outlet.
    For every 1000 volts of electricity you will get an arc of approximately 5mm. That is why battery backups and surge protection is of little use with a close proximity or direct strike.
