I need a laptop
reeltrouble1
looking for something portable, I will be doing some band music with it, midi and usb, likely using Cakewalkl or some such program, some internet browsing. Apple or Windows based fairly flexable, no junk, the more storage the better but needs to be at least a mid-line model with wi-fi and some sort of writer. so please hit me with something you might want to move that might fit the bill.
puters are not my strong point by any means but I do use them and have a bit of knowledge, so try to explain a bit or expect questions for acronyms.
RT1
RT1
Post edited by reeltrouble1 on
are you wanting a New or Preowned/used one...
As a point of reference, I think you would need to spend about $600 - $700 to get a good quality one brand new.
If you can find a good deal at tech bargains dot com, the Dell Vostro 1520 with upgraded 1440 x 900 anti-glare screen and webcam is a good choice (probably low $600 + tax range): http://www.studentbuyingguide.com/2009/05/dell-vostro-1520-review/
Lenovo T400 or T500 (usually just choose base configuration with integrated graphics on left side of webpage, and make sure you get good resolution screen and webcam if you want); probably high $600 - $700 range with 15% of coupon often floating around the web; T500 is more of a desktop replacement http://forum.notebookreview.com/showthread.php?t=365492
If you have larger budget, current generation Macbook or Macbook Pro are great choices (screen is supposed to have better viewing angles than previous generations and you can dual boot Windows and even get something like VMWare Fusion and run both operating systems at same time). Watch Apple refurb store (people say products are like new condition and come with full warranty): http://store.apple.com/us/browse/home/specialdeals/mac?mco=OTY2ODY3Nw
If portability is very important (like college student that always keeps laptop in backpack), I'd say probably focus on 13.3 or 14.1 inch widescreen laptops; 15.4 inch is primarily more of a desktop replacement with occasional portability.
If you do decide to go used, here is a much more active computer hardware marketplace: http://forums.anandtech.com/forumdisplay.php?f=19
Good luck!
www.delluniversity.com | 1-866-328-1898
I am looking for a used one, perhaps by a little old lady who visited sites of ill-repute???
RT1 -
reeltrouble1 wrote: »I am looking for a used one, perhaps by a little old lady who visited sites of ill-repute???
RT1
reeltrouble1, I sent you a PM.THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma -
back at you.
Thanks.
RT1 -
Tim,
I sent you another PM. Let me know.
JasonTHE SYSTEM
Tim?
It's Ted if you're talking about RT1
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »Tim?
Oh jeez...my bad. Sorry about that Ted.THE SYSTEM
