need advice on new home speaker placement
ted538
I just bought a new home in the Big Easy...need some advice on rear rt35i set up...where do you think I should put them?...what should I use to mount them? I was thinking from the ceiling in both corners...any ideas are appreciated
Post edited by ted538 on
Without knowing your room layout, I personally have no idea. Corner loading a surround is not a preferred method.
Here are a couple links to help you:
www.dolby.com
http://www.polkaudio.com/home/faqad/index.php
They are very helpful.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
