need advice on new home speaker placement
ted538
ted538 Posts: 63
I just bought a new home in the Big Easy...need some advice on rear rt35i set up...where do you think I should put them?...what should I use to mount them? I was thinking from the ceiling in both corners...any ideas are appreciated
  • dorokusai
    dorokusai Posts: 25,661
    edited October 2003
    Without knowing your room layout, I personally have no idea. Corner loading a surround is not a preferred method.
    Here are a couple links to help you:
    www.dolby.com
    http://www.polkaudio.com/home/faqad/index.php
    They are very helpful.
