LSiC Possible Blown Woofer
JohnLocke88
Hello. Just picked up a LSiC off craigslist today. I think one of the woofers might be blown.
Does anyone know, is one woofer supposed to sound different from the other (e.g., only produce lower frequency sounds... if not, if one sounds less 'full,' does that mean its blown.)
Any info / guidance appreciated.
Post edited by JohnLocke88 on
From: http://www.polkaudio.com/homeaudio/lsi/index.php#lsicCascade Tapered Array
Cascade Tapered Array is an advanced crossover configuration providing wider dispersion and greater midrange accuracy on multi-driver speakers. It's only used on higher end speakers. Your mids will sound more natural and every seat will hear spectacular sound. Pretty neat?
Driver 1: LPF at 200Hz, 12dB/oct.
Driver 2: LPF at 2.4kHz, 12dB/oct.
Tweeter: HPF at 2.4kHz, 18 dB/oct."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Lol, That deserved a, "read the specs noob."
Thanks Face. -
So that's what product manuals are for!?:eek:
;) The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
