Pro Box enclosures any good?
KrazyMofo24
I just picked up a Pro Box 112HB a 12'' sealed enclosure. It's for a JL audio W6v2.
I wanted to know if anyone knows if this is a good brand/box. I purchased it for sound quality over being louder.
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
whats the measurements so i can see how many ft3 it isReceiver:Yamaha RX-V363
Center:Klipsch RC-3
Fronts: DIY #01EN or Klipsch XF-48
Surrounds:Klipsch KG 4.5
Subwoofer left:Polk Audio PSW-110
Subwoofer Right:Klipsch KSW-12
Subwoofer Center: DIY DAYTON titmk3 400 -
Airspace: 1.30 cu. ft.
Dimensions:
W: 15.5"
17.5" H: 14"
Setup:
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
ok thanks ill put it in winisd looks pretty good, with the proper amp and filter you could expect at least 120 db with cabin gain. By the way what you planning to power it withReceiver:Yamaha RX-V363
Center:Klipsch RC-3
Probox makes EXCELLENT boxes, but to put a W6 in a prefab is borderline illegal...or at least should be
exalted512 wrote: »Probox makes EXCELLENT boxes, but to put a W6 in a prefab is borderline illegal...or at least should be
-Cody
I haven't had a chance to really listen to it yet, but so far I don't think it's performing the way it should. I could be wrong. I'm going to get an SPL meter and measure it when I get a chance.Setup:
A w6 isnt going to get real loud...its an SQ sub, not spl.
SQ is definitely what I want. I gave it another listen I can say it sounds pretty good. I don't have a lot of experience listening to higher quality subs so wasn't sure to expect. Finally got everything installed tonight, going to listen to it some more tomorrow.Setup:
-Cody
+1 to what ^ saidSamsung LN52A650 : PS3 : RTi A7s : CSi5 : SVS PC12-NSD : Pioneer VSX-9040THX : Emotiva XPA-3 =
I don't know about how loud a 12W6 sub will get. In a ported enclosure I think you would be very surprised...
