Fxia6 Question about Placement . . .
SolidSqual
Am I supposed to have the midrange driver facing towards the listening position or away when the speakers are on the back wall behind the listening position? I think based on the instructions from Polk, the driver should be aimed away, but I could be wrong.
Can I get a confirmation?
Mike
Mike
Post edited by SolidSqual on
Left and right don't change depending on if they're side-mounted or rear. That would orient the main drivers to the outside in a rear-mounted configuration.SolidSqual wrote: »Am I supposed to have the midrange driver facing towards the listening position or away when the speakers are on the back wall behind the listening position? I think based on the instructions from Polk, the driver should be aimed away, but I could be wrong.
Mike -
Yes, they should be aimed away. Look on the back they're labeled right left.
I went against the grain and reversed mine. I have the mid driver facing me. I like the sound better that way so I'll say try both ways and see what sounds best. -
That way, when you turn around to look at them, left and right will be correct...
Ok thanks guys. This has been nagging me lately. Much appreciated.
Mike
