Emotiva XPA-5 vs. NAD T955 ?
Gulfstrings
Currently driving Polk A7s, CSi A6, FXi A6s and PSW111(x2) speaker package with an Onkyo SR707 7.2 receiver. The A7s are bi-amped via two outputs from the Onkyo making this a 5.2 system.
We enjoy both music:
- Onkyo DX755 CDP
- Marantz CD5003 CDP
- Technics SL1301 table (vintage like me)
And movies:
- Pioneer BDP-320
- Panasonic DMR-EZ27 DVD Player/Recorder
I enjoy the Pure Audio feature of the Onkyo and the movie audio is pretty good, but the Polks 'sound' like they could use more horsepower from both source types.
Is adding one of the two products above a workable solution?
Would the two 5 channel amps noted give the Polks what they need to be their best?
Between the two amps - at similar price points - is there a clear choice?
Thanks for the help.
Dave
- Onkyo DX755 CDP
And movies:
- Pioneer BDP-320
Dave
Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Technics SL-1301/Shure M97xE
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Post edited by Gulfstrings on
Gulfstrings wrote: »Currently driving Polk A7s, CSi A6, FXi A6s and PSW111(x2) speaker package with an Onkyo SR707 7.2 receiver. The A7s are bi-amped via two outputs from the Onkyo making this a 5.2 system.
- Onkyo DX755 CDP
And movies:
- Pioneer BDP-320
Is adding one of the two products above a workable solution? Should be. It will depend on your expectations.
Would the two 5 channel amps noted give the Polks what they need to be their best? Same as above.
Between the two amps - at similar price points - is there a clear choice? Some would say "yes", others would say "no" bottom line is, only you can make that call for what's right for you.
Dave
Wish I could say more, but that's the way I see it. Both get good comments from owners, but I think they would have a little different sound from each other. Have you considered any others? -
Thanks for your response. Haven't considered other amps yet ... just beginning this process.
Both Emotiva and NAD seem respected here and being new to 'higher' end equipment I'm trying to absorb as much as possible. The current selling price for either fits comfortably as my last spend for this project, or at least my last 'planned' spend, assuming a power amp is worth it at all.
One thing I find interesting, the NAD amp, at this dollar amount, is advertised as deeply discounted while the Emotiva ads this as their list. Difference in sales and distribution costs? or is the NAD justified at a near $1500 retail?
Appreciate everone's input.
Thanks,
DaveMarantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2 -
Ooops, I missed one. We need a Bose, Monster and Emotiva sticky....how could I haved miss Emotiva. It's too early for popcorn too......hmm.
Gulf, it's all up to you. There are some strong opinions here about Emotiva - do another search- or save some time and don't bother. I'll tell you the deal....Some people with "experience" in audio and on this board aren't fond of Emotiva. A lot of people who are in your spot have been VERY Happy with their purchase of Emotiva products and saved some $$ over other brands in the process.
Believe you can get a trial with the Emotiva. Give it a try if it's not what you want no harm no foul.
You'll find there are very few definitive answers here or elsewhere in audio. It's a learning (and FUN) process. Stick around and get your read on.
Good luck with your endeavour.
RichAnalog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
Emotiva is an internet direct company as is Outlaw Audio, they have no middlemen that have to get paid, so they can offer their products for less money.
If you want a good product new, then Emotiva & Outlaw audio are good choices. Go for it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Definitely power the front soundstage and go for a 3 channel amp at least. +1 on the Outlaw Audio or Emotiva gear. Worth a shot at least, or check out Sunfire on audiogon.Here's a good one
http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1272254132&/Sunfire-Cinema-Grand-SignatureShoot the jumper.....................BALLIN.............!!!!!
What is the budget on the amp?
Both of these units are priced at $799. That seems consistent with the level of investment spent so far for my new system, Polk, Onkyo, etc, assuming the cost will make a significant difference.
Unfortunately, the Tampa Bay area lost its better electronics outlet (Sound Advice) and there are no comparable stores to do comparos. As such, I find myself relying on the kindness of strangers a/k/a, the good folks here, as well as various net forums.
While I don't want to throw diamond money in to a ruby pond, I'm hopeful that the system I have can be enhanced by one of these - or another - power amp.
Thanks,
DaveMarantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
You might consider saving some money and going with a three channel amp.
Most of the power goes to the front three speakers. You can leave the FXiA6 surrounds to the Onkyo.
The XPA-3 would be a good choice to consider for powering your RTiA7's and CSiA6.
Definitely thought about this when exploring Emotiva's site. But the price difference between the 3 and the 5 may be worth admission if the same 'boost' is realized across all speakers.
Thanks,
DaveMarantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
All -
Pardon another noob question ... but with either amp it looks like the subs (PSW111 x2)wiill continue to be powered by the Onkyo only. Does this mean the subs will be 'short changed' in any way?
Thanks,
DaveMarantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Gulfstrings wrote: »Both of these units are priced at $799. That seems consistent with the level of investment spent so far for my new system, Polk, Onkyo, etc, assuming the cost will make a significant difference.
Thanks,
Dave
An amp is certainly going to improve your system.
I don't have any in-home experience with the NAD or Emotiva gear, so I won't comment on these units, but you might want to look at some of the used gear that crops up here and places like Audiogon before making a purchase.
Outlaw, B & K, Parasound...would all be good options to consider as well. I have experience with all of those brands and recommend them.
Gulfstrings wrote: »All -
Thanks,
Dave
No, your subwoofers are powered by their own amps. -
With Onkyo 707 you have enough Power to Drive your Polk Speakers Adding Power Amps would increase your Power but would not neccesarily improve sounds. What you probably is to buy better speakers eg Polk LS1 seriesGulfstrings wrote: »Currently driving Polk A7s, CSi A6, FXi A6s and PSW111(x2) speaker package with an Onkyo SR707 7.2 receiver. The A7s are bi-amped via two outputs from the Onkyo making this a 5.2 system.
- Onkyo DX755 CDP
And movies:
- Pioneer BDP-320
DaveEAR -
Whoa, I hate it when to noob bone sticks out like this. Still, if you don't ask ...
BTW, I did take a look at the Outlaw amps. Appear too pricey (new) for this project.
Thanks,
DaveMarantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Uh... the 707 will absolutely not power LSi series to satisfaction for various reasons.
Dedicated power amps will improve sound, give much more headroom, and let the receiver do what it was really designed to do, that being process a signal. RTi series love power. Give it to them.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thanks,
Dave
The vast majority of subs are self powered, they just need to be hooked up to the receiver in order to know WHEN to go thump.:)Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Welcome to Club Polk Elton.
Adding separate amplification is almost always an improvement to the system. It allows ANY speaker to operate to their full potential. Which is something most receivers can't do.
It's always better to make sure you are getting the best out of the equipment you already have rather than getting new equipment that will sound different but not necessarily better.
This would be true of getting the LSI's which DEFINATELY need more power to sound their best! They will not only sound better but operate better.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
