4 MM2124s in bandpass box
Systems
Systems Posts: 14,872
edited October 2003 in Car Subwoofer Talk
hello i want to put four of these 2124 subs in my bandpass box but i will have to face one of them to another one on one side and the same on the other side of the enclosure will this work well with these subs and also i want to run 1000watt amp to all for at the moment will want to upgrade to on 1000 watt per pair of subs but not sure it this configuration would work well ?
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited October 2003
    dont waste your money getting two 1000 watt amps -- you dont need that much powr.
    in a bandpass box, you can get away with less power and get the same volume as more power in a sealed box.
    now, taking that into consideration, the 2124's are 400 watts rms... so why not just go by the rating, no need to overpower them...
    400 x 4 = 1600 watts.
    four 4 ohm subs in parallel = 1 ohm.
    i would suggest an amp that is 1500 to 1600 watts x 1 at 1 ohm.
    Hifonics Brutus BX1500D ... $380 after instant rebate
    1500 x 1 at 1 ohm rms.
    http://www.sounddomain.com/shop/item.pl?sku=HIFBX1500D
    or two amps that are about 750 - 800 x 1 at 2 ohms
    Mtx Thunder 500D ... $300 each x 2 = 600 bucks factory old stock clearance.
    each will come out of the box at over 700 x 1 at 2 ohms and 12.5 volts, and near or over 800 x 1 at 14.4 volts.
    http://www.mitekfactoryoutlet.com/products/product.cfm?PN=THUNDER500D
    The Artist formerly known as PoweredByDodge
  • Systems
    edited October 2003
    what would be the wiring order on the subs that are right up to each other would one have to be out of phase than the other so it would be push/pull or should the phase be selected from the amp ?
    Testing
    Testing
    Testing
  • PoweredByDodge
    edited October 2003
    if they're bolted to each other - wire one out of phase with the other on the speaker.
