basic understanding of sda
superjunior
OK, I feel really dumb asking this question, but as I tell my workers the only dumb question was the one never asked so here it goes. Can someone please take a few minutes and help me understand the basic concept of the sda. In plain English please, or in a way that folks un-familiar with these speakers can understand. I've read publications like this http://www.polksda.com/srsreview.shtml
and I still don't fully understand. something about the extra drivers canceling out the interaural crosstalk on the other speakers drivers? is that what the ic is for? what is interaural crosstalk? I just don't get it, at least not in the complex technical way that its usually explained. Can someone dummy up the definition of the sda a bit to make it a little more understandable for those of us new to the technical aspects of audio. I'm trying to better understand sda's (my 2b's for starters). I'm not sure exactly what the 'sda effect' is so I'm not even sure what to listen for. I'm sure this has been gone over before, but to me at least, an open discussion is a lot more interesting and beneficial than pulling up some info from an old archive. thanks for any help
Dan
Dan
panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one
Post edited by superjunior on
Good post and good question. I know I had no clue from reading those types of informational posts geared toward people who know more than I do. I didn't understand until George talked to me about it, but I wouldn't dare try and repeat for a fear of messing it up. I'm sure someone will be able to do it justice! It may be nice to be a sticky: SDA Effect Defined - For Newbies, or something like that.
James2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player -
the basics are that one set of drivers(either the inboard or outboard column) cancel out the cross-talk distortion of the main drivers in the oposite speaker. This restores the true stereo image that arrives to the listener.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
That review is about as simple as it's going to get. Do you have a specific question? Do you know what interaural crosstalk is?
Our ears are seperated by our skull. When you have a L and R stereo speaker with sound coming from both sides the signal from the Left speaker is delayed reaching our right ear because of the distance between our ears. Same goes for the Right signal reaching our left ear. That's interaural crosstalk. What a very simplified answer about SDA's is this: The outside driver array on SDA's plays a low level signal from the opposite channel (the Left SDA has low level signal info from the Right channel playing in the outside driver array which many refer to as the "dimensional driver") same is true for the Right channel
By playing this low level signal from the opposite channel in each dimensional array the delay (interaural crosstalk) is eliminated and it opens up the sound like no other speaker I know. This is not a gimmick it's an aural phenomenon. This is what headphones sound like. Of course proper placement and room dimensions, etc can lessen or increase the effect.
One of the main keys is the regular drivers (the inner drivers) and dimensional drivers (outter drivers) are spaced approx the same distance from each other as our ears. That is the short and skinny idea behind SDA's
Hope this helps
Maybe this is one way of thinking about it. If you consider that each speaker has a "cone" of sound coming from it and the sda effect simply makes both speakers act as a single "cone" thereby producing such a large sound stage. The interaural sound waves that cross over are cancelled out.
Just my way of taking it down to the most simplistic understanding that I have that I can put into words.Home Theater
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner -
Headphones have no (or extremely little) interaural crosstalk. What comes out of the left earpiece is heard by the left ear, but not the right. What comes out of the right earpiece is heard by the right ear, but not the left.
Ordinary loudspeakers have LOTS of interaural crosstalk--you hear the left speaker with both ears, and you hear the right speaker with both ears. There's phase, frequency-response, and amplitude cues that make the sound at the "opposite" ear different from the sound at the "direct" ear.
In both cases, folks have "improved" the sound by manipulating the signal to a "middle ground". Apparently, SOME crosstalk is good, but no crosstalk and lots of crosstalk are both "bad".
SDA (and Carver's Sonic Holography) use reverse-polarity sound to cancel some but not all of the crosstalk from loudspeaker listening.
Headroom's headphone amplifiers use a blending circuit to add some crosstalk to headphones. -
so far everyone that has posted has taken me one step farther in better understanding sda's. before this I had no clue what inter aural crosstalk was. So from what I gather thus far the ic is to send a low level signal to the outside drivers (dimensional drivers) of the opposite speaker? creating a sound that more represents a single sound stage as opposed to sound coming from two different locations? Is that what is considered the sda effect? How would the speakers respond without the ic? I really do appreciate everyones input. I gotta run though, I'll check back later. thanks again
Danpanasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
^^^DING DING DING^^^
we have a winner!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
There's no harm done by not using the interconnect cable. You won't damage the speakers or the amp by NOT using the cable.superjunior wrote: »How would the speakers respond without the ic?
My 1Bs sound almost exactly the same without the cable, except that the soundstage collapses to the area between the speakers instead of encompassing a space extending to each side beyond the speakers. (Further left than the left speaker, further right than the right speaker.)
Apparently, other SDA models may not have the same tonal balance with or without the cable; at least that's what I've been told. No direct experience with anything but the 1B here. -
Hope this helps
Well written. I remember when I first got into Polks I had nary a clue about this. -
Very cool and informative thread. Thanks! Someday I'll get my ears on a rig with SDAs.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk TSi500s Vr3 Fortress modded
polk CS20 center channel Vr3 Castle modded
polk Owm 3 surrounds
polk PSW505 -
Slinger182 wrote: »Very cool and informative thread. Thanks! Someday I'll get my ears on a rig with SDAs.
You are welcome to drop by anytime!:):cool:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Be careful what you wish for..:cool:Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk PSW505 -
SDA is not an effect, regular stereo is. SDA corrects the stereo effect.Political Correctness'.........defined
President of Club Polk -
Slinger182 wrote: »Be careful what you wish for..:cool:
bring it!!!
The danger of hearing SDA is trying to live without it afterwards. Be prepared to need to spend money to achieve it.;)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Sounds like a plan I'll definitely take you up on your offer one of these days.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk PSW505 -
you are welcome here anytime as well. I live near O'hare airport.Home Theater
Rears: Polk LSiFX
SDA is a gimmick for ignorant lemmings..........
But combined with Bob Carvers' gimicky Sunfire amps they make one solid sound.:DMost people just listen to music and watch movies. I EXPERIENCE them.
____________________
Pool: Atrium 60's/45's -
tony millard wrote: »But combined with Bob Carvers' gimicky Sunfire amps they make one solid sound.:D
PLus 1000 Tony... how's things man!
Give me a call sometime.:)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Here's an SDA Diagram scanned from my SRT manual.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
oh go lay an egg, do lemmings lay eggs?
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
nooshinjohn wrote: »bring it!!!
So true, Oh so true.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
SDA defined. And it only took one post. Awesome."The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson. -
SDA effect is awesome even to ignorant lemmings.ProJect Perspective II Turntable & Benz Micro Ace
ProJect Tube Box II & Philips/Amperex tubes
Luxman L-430 Integrated
Polk SDA 1C's -
Put the lemmings in your pants and eat cheeto's while listening. It enhances the SDA effect. superjunior told me so. It is gospel.
And this coming from the man that told Richard Gere that gerbils and hamsters are loads of fun.:rolleyes::DThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Between Brock's verbal description and dpowell's schematics I think you get the picture.
EVERYBODY who has ever logged on to this site has been 'confused' by these Polksters constant jabber about SDAs and their 'effect'. I know I was. The easiest thing to do is use the search engine...or NOW...just read this thread. BUY a pair.....and you'll know.
That all enveloping space is pretty magical. When you first get it right and get a good recording that highlights the effect, you keep looking for the extra speakers in vain!
And some people even decide to just go 2 channel for HT because the effect (so-called and rightly so by f1nut, above) is just that GOOD!
Enjoy...good thread!
its chease PUFFS Russ, c'mon man your slackin..
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
cnh
thanks C, I know this thread has helped me out a lot. I am stoked now with this bit of knowledge for my next sda session and thanks for everyones input. How does one go about making a sticky out of a thread? I think the basic understanding of sda might just be worthy of that.panasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one
