basic understanding of sda
superjunior
superjunior Posts: 1,632
edited February 2010 in Vintage Speakers
OK, I feel really dumb asking this question, but as I tell my workers the only dumb question was the one never asked so here it goes. Can someone please take a few minutes and help me understand the basic concept of the sda. In plain English please, or in a way that folks un-familiar with these speakers can understand. I've read publications like this http://www.polksda.com/srsreview.shtml
and I still don't fully understand. something about the extra drivers canceling out the interaural crosstalk on the other speakers drivers? is that what the ic is for? what is interaural crosstalk? I just don't get it, at least not in the complex technical way that its usually explained. Can someone dummy up the definition of the sda a bit to make it a little more understandable for those of us new to the technical aspects of audio. I'm trying to better understand sda's (my 2b's for starters). I'm not sure exactly what the 'sda effect' is so I'm not even sure what to listen for. I'm sure this has been gone over before, but to me at least, an open discussion is a lot more interesting and beneficial than pulling up some info from an old archive. thanks for any help
Dan
panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
Post edited by superjunior on
  • Pycroft
    Pycroft Posts: 1,961
    Good post and good question. I know I had no clue from reading those types of informational posts geared toward people who know more than I do. I didn't understand until George talked to me about it, but I wouldn't dare try and repeat for a fear of messing it up. I'm sure someone will be able to do it justice! It may be nice to be a sticky: SDA Effect Defined - For Newbies, or something like that.
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
    nooshinjohn Posts: 25,922
    the basics are that one set of drivers(either the inboard or outboard column) cancel out the cross-talk distortion of the main drivers in the oposite speaker. This restores the true stereo image that arrives to the listener.
    heiney9 Posts: 25,432
    That review is about as simple as it's going to get. Do you have a specific question? Do you know what interaural crosstalk is?
    Our ears are seperated by our skull. When you have a L and R stereo speaker with sound coming from both sides the signal from the Left speaker is delayed reaching our right ear because of the distance between our ears. Same goes for the Right signal reaching our left ear. That's interaural crosstalk. What a very simplified answer about SDA's is this: The outside driver array on SDA's plays a low level signal from the opposite channel (the Left SDA has low level signal info from the Right channel playing in the outside driver array which many refer to as the "dimensional driver") same is true for the Right channel
    By playing this low level signal from the opposite channel in each dimensional array the delay (interaural crosstalk) is eliminated and it opens up the sound like no other speaker I know. This is not a gimmick it's an aural phenomenon. This is what headphones sound like. Of course proper placement and room dimensions, etc can lessen or increase the effect.
    One of the main keys is the regular drivers (the inner drivers) and dimensional drivers (outter drivers) are spaced approx the same distance from each other as our ears. That is the short and skinny idea behind SDA's
    Hope this helps
  • BAD ASP
    BAD ASP Posts: 361
    Maybe this is one way of thinking about it. If you consider that each speaker has a "cone" of sound coming from it and the sda effect simply makes both speakers act as a single "cone" thereby producing such a large sound stage. The interaural sound waves that cross over are cancelled out.
    Just my way of taking it down to the most simplistic understanding that I have that I can put into words.
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
  • Schurkey
    Schurkey Posts: 2,122
    Headphones have no (or extremely little) interaural crosstalk. What comes out of the left earpiece is heard by the left ear, but not the right. What comes out of the right earpiece is heard by the right ear, but not the left.
    Ordinary loudspeakers have LOTS of interaural crosstalk--you hear the left speaker with both ears, and you hear the right speaker with both ears. There's phase, frequency-response, and amplitude cues that make the sound at the "opposite" ear different from the sound at the "direct" ear.
    In both cases, folks have "improved" the sound by manipulating the signal to a "middle ground". Apparently, SOME crosstalk is good, but no crosstalk and lots of crosstalk are both "bad".
    SDA (and Carver's Sonic Holography) use reverse-polarity sound to cancel some but not all of the crosstalk from loudspeaker listening.
    Headroom's headphone amplifiers use a blending circuit to add some crosstalk to headphones.
  • superjunior
    so far everyone that has posted has taken me one step farther in better understanding sda's. before this I had no clue what inter aural crosstalk was. So from what I gather thus far the ic is to send a low level signal to the outside drivers (dimensional drivers) of the opposite speaker? creating a sound that more represents a single sound stage as opposed to sound coming from two different locations? Is that what is considered the sda effect? How would the speakers respond without the ic? I really do appreciate everyones input. I gotta run though, I'll check back later. thanks again
    Dan
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
    ^^^DING DING DING^^^
    we have a winner!
  • Schurkey
    There's no harm done by not using the interconnect cable. You won't damage the speakers or the amp by NOT using the cable.
    My 1Bs sound almost exactly the same without the cable, except that the soundstage collapses to the area between the speakers instead of encompassing a space extending to each side beyond the speakers. (Further left than the left speaker, further right than the right speaker.)
    Apparently, other SDA models may not have the same tonal balance with or without the cable; at least that's what I've been told. No direct experience with anything but the 1B here.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    heiney9 wrote: »
    Hope this helps
    Well written. I remember when I first got into Polks I had nary a clue about this.
  • Slinger182
    Slinger182 Posts: 512
    Very cool and informative thread. Thanks! Someday I'll get my ears on a rig with SDAs.
    Panny 55-st30 plasma
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk TSi500s Vr3 Fortress modded
    polk CS20 center channel Vr3 Castle modded
    polk Owm 3 surrounds
    polk PSW505
    Slinger182 wrote: »
    You are welcome to drop by anytime!:):cool:
  • Slinger182
    Be careful what you wish for..:cool:
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk PSW505
    F1nut Posts: 51,767
    SDA is not an effect, regular stereo is. SDA corrects the stereo effect.
    Slinger182 wrote: »
    bring it!!! :p
    The danger of hearing SDA is trying to live without it afterwards. Be prepared to need to spend money to achieve it.;)
  • Slinger182
    Sounds like a plan I'll definitely take you up on your offer one of these days.
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk PSW505
  • BAD ASP
    BAD ASP Posts: 361
    Slinger182 wrote: »
    you are welcome here anytime as well. I live near O'hare airport.
    Rears: Polk LSiFX
  • lightman1
    lightman1 Posts: 10,796
    SDA is a gimmick for ignorant lemmings..........
    Tony M Posts: 11,621
    But combined with Bob Carvers' gimicky Sunfire amps they make one solid sound.:D
  • mmadden28
    mmadden28 Posts: 4,283
    Try this video from the source:
    http://www.youtube.com/watch?v=BVkYNUbuSLY
    ____________________
    Pool: Atrium 60's/45's
    PLus 1000 Tony... how's things man!
    Give me a call sometime.:)
  • dpowell
    dpowell Posts: 3,081
    Here's an SDA Diagram scanned from my SRT manual.
  • superjunior
    lightman1 wrote: »
    oh go lay an egg, do lemmings lay eggs? :D
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • ESavinon
    ESavinon Posts: 3,067
    bring it!!! :p
    So true, Oh so true.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • xj4094dg
    xj4094dg Posts: 1,158
    mmadden28 wrote: »
    SDA defined. And it only took one post. Awesome.
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • Hypnotoad
    Hypnotoad Posts: 44
    SDA effect is awesome even to ignorant lemmings.
    ProJect Perspective II Turntable & Benz Micro Ace
    ProJect Tube Box II & Philips/Amperex tubes
    Luxman L-430 Integrated
    Polk SDA 1C's
  • lightman1
    Put the lemmings in your pants and eat cheeto's while listening. It enhances the SDA effect. superjunior told me so. It is gospel.
    lightman1 wrote: »
    And this coming from the man that told Richard Gere that gerbils and hamsters are loads of fun.:rolleyes::D
    Between Brock's verbal description and dpowell's schematics I think you get the picture.
    EVERYBODY who has ever logged on to this site has been 'confused' by these Polksters constant jabber about SDAs and their 'effect'. I know I was. The easiest thing to do is use the search engine...or NOW...just read this thread. BUY a pair.....and you'll know.
    That all enveloping space is pretty magical. When you first get it right and get a good recording that highlights the effect, you keep looking for the extra speakers in vain!
    And some people even decide to just go 2 channel for HT because the effect (so-called and rightly so by f1nut, above) is just that GOOD!
    Enjoy...good thread!
    cnh
  • superjunior
    lightman1 wrote: »
    its chease PUFFS Russ, c'mon man your slackin.. :p
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    cnh wrote: »
    cnh
    thanks C, I know this thread has helped me out a lot. I am stoked now with this bit of knowledge for my next sda session and thanks for everyones input. How does one go about making a sticky out of a thread? I think the basic understanding of sda might just be worthy of that.
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
