Suggestions??? new Rti a9
RCG5579
RCG5579 Posts: 4
Just purchased Rti a9's from newegg($599) had to do it. I have a Yamaha 5790 with bose 601 series III currently. Hope the 5790 will get me by for now but will be looking for a 2 channel amp. Any suggestions for wire and amp to get would be helpfull. I plan on completing the rti a9's with a center channell, surrounds, and subwoofer.
Post edited by RCG5579 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited February 2010
    What's your budget?
  • Huck344
    Huck344 Posts: 453
    What is your budget for the amp? You may want to get a 3 channel amp since you plan on going full surround. You can probably power your surrounds and rears through the Yamaha.
    Regarding speaker wire, you can go cheap, but good (monoprice) to expensive (Kimber). It all depends on what you want to spend as well.
    Eric. . .
  • thsmith
    thsmith Posts: 6,082
    If your AVR has preouts which I assume it does, there are many good choices. Adcom 555 ot Carver TFM25-35-45 plus some Parasounds.
    I use a Denon that is rated about the same WPC as your Sony and find it drives my center (CSiA6) and Rears (RTi38s) just fine.
    If you are looking for a new AMP I have no suggestions, all my stuff is used.
    AFA speaker wire, signal cable, Bluejeans or some raw Audio QUest T4 and make your own terminations. Monoprice is ok for cheap speaker wire but a step up for not too much more money is worth it.
  • RCG5579
    RCG5579 Posts: 4
    Thanks for the help. I have been looking at some knukonceptz speaker wire around $1 a foot 10 or 12 gauge???? The adcomm amps look great but a little to expensive. I was looking more around $600-$700 for an amp. I noticed the Emotiva xpa-3 at $600 which is 3 x 200 wpc would that be enough watts???
  • thsmith
    Yes it would be. Some pretty nice Carver TFMs can be had for $250-$400 just make sure it has been serviced recently. I just sold a very nice TFM-45 serviced by Rolland for $600. Not that WPC count that much but it was rated at 375wpc. I am using a 40wpc tube amp now that drives my 1Cs just fine.
  • sandworms
    sandworms Posts: 1,043
    did you say $599 for rtia9's?!!
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • superjunior
    superjunior Posts: 1,632
    RCG5579 wrote: »
    I run that amp with my a9s and it sounds very good. I would recommend the csi a6 for a center. congrats on your new speakers
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • RCG5579
    RCG5579 Posts: 4
    Looks like they were on sale for only 1 day $599 each and the csi a6 for $299(should have bought it also). Im definitley getting the csi a6 for the center. Goin to see what I can get 1 of those adcom 5503's for. Thanks
  • klennop
    klennop Posts: 30
    I was in your same boat. I have the A9's A6 center and some OWM3's for surrounds and wide DSX.
    I have a Denon 4310 that powers everything fine, however I have always heard how running a good amp with considerable power would warm up the A9's. I debated back and forth between the Emotiva 3 or 2 channel amp. I don't use my TV speakers at all so in reality I use home theatre more than 2 channel stuff and I had read conflicting info about running the same amount of power to the front 3 speakers for HT setups. In a perfect world you should, however other people say it didn't matter much or they didn't notice a big difference.
    I decided on the Emotiva 2 channel amp.
    1. Because it is built more stout than the 3 channel amp.
    2. A lot of people really like the amp.
    3. Emotiva just released info that now they are putting on paper that the XP-2 is up 50watts per channel. They said it was really under rated before, so now it is at 300 watts per channel (8 ohm) compared to the XP3 at 200 watts per channel (8 ohm).
    4. Now that the receiver doesn't have to power the main towers, it has the 4 small surrounds and the center to drive, so the power output should be higher going to those speakers. Also the receiver will not be working as hard no matter what I am doing 2 channel or HT.
    Now I haven't got the XP2 yet but if I don't like it, I will swap it for the 3 channel. However I think I will be fine. Also I am not going to bi amp or anything with the center because most people said that doesn't do squat.
    If I had unlimited money I would have done something else but I am on a budget.
    Denon 4310
    (2)Emotiva XPA-2
    (2)Polk RTiA9, Polk CSiA6, (2)Polk DSW660, (4) Polk OWM3
    Panamax M5400-PM
    Samsung 50" Plasma
    XBox One w/external HD, AppleTV, Samsung Blu Ray
  • RCG5579
    RCG5579 Posts: 4
    Just got my two rti a9's been listening for about 1 hour and I'm amazed. In 2 channel stereo my reciever power seems fine. Really low bass which I love!!!! Be back later going to listen to music.
  • Hoosierbronco
    Hoosierbronco Posts: 60
    May want to keep an eye on E-prey for a CSi-5 , same center speaker , just doesn't have the rounded edges on the cabinet. Very little difference IMHO.
    I just got one for $175 , excellent shape.
    Plasma : Panny 54G25
    Receiver : antique Sony :mad:
    BD/DVD/CD : OPPO BDP 93
    Fronts : Polk Monitor 10B
    Center : CSi5
    no rears yet , no sub ... Looking at RTia3's first then 9's and a NAD T 747 ... maybe
  • domflane
    domflane Posts: 653
    Congrats on those A9's, they're some dramatic looking, kick **** speakers. Enjoy . . .
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • EDUBAG
    EDUBAG Posts: 403
    First of all, congrats on your speakers, good for you you found a great deal!!!.
    I do not know if you guys are familiar with the brand of amps qsc, but i can tell you that we have used it in our professional system and they are great.
    They offer a good professional amp (the gsx3 or gsx5), the gsx3 offers 300 watts per channel driven 8 ohm at a thd of 0.05%.
    Remember the greater power from the amp the better is going to move your speaker and the less volume you are going to need, this last resulting in a great clean sound without distortion.
    The qsc gsx3 cost about 300 delivered.
    Go to www.qsc.com and check it out.
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • Squishy Tia
    Squishy Tia Posts: 79
    I personally like the two channel Adcom 555 (MkII or SE, whichever you can get cheaper). The original 555 (non-rackmount versions) are good too, but lack the extra per-channel fuse protection, something you may want with the A9s and the power you'll shove through them.
    My only gripe about Onkyo AVRs (I own the TX-NR5007) is that the Audyssey setup uses a curve with a rather steep rolloff past 6.3kHz, requiring a manual adjustment of ALL channels' EQ to +2 or +3db at the 6300Hz and higher EQ bands in order to simulate the preprogrammed Audyssey "flat curve", which is only used, ironically with THX modes. Kinda backasswards there, don'tcha think? :p
    Edit: Damned smileys on these forums are different from every other one I'm on.
  • Hoosierbronco
    Center : CSi5
