33 Minute XP Installation Hangup
Also, it is the disc that came with the netbookMusic is like candy, you have to get rid of the rappers to enjoy it
mini 10?
service tag por favorMain Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Service tag gnxkhj1 express service code 36275622589. Its a mini9.Music is like candy, you have to get rid of the rappers to enjoy it
ill look.
i'm guessing the diagnostics passed?Main Surround -
Diagnostics?Music is like candy, you have to get rid of the rappers to enjoy it
Should be an option when you hit 0 on boot.Main Surround -
Never tried itMusic is like candy, you have to get rid of the rappers to enjoy it
To run the diagnostics, there should be an option when you press F12 for the boot menu during the POST.Ludicrous gibs!
Just install hackintosh lol
http://www.gizmodo.com.au/2009/10/how-to-hackintosh-a-dell-mini-10v-into-the-ultimate-os-x-netbook/HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
exalted512 wrote: »I'm using the disc I got with it from Dell via a usb powered disc drive.
What I'm about to propose is a very, very remote possibility so use this information as you see fit.
I have seen a Windows install freeze like that on a laptop using an external cdrom drive powered by USB only. If it's available, try using another external dvd/cd drive that is powered by an ac adapter.
http://support.microsoft.com/kb/828267
Good luck -
Does it have a recovery partition on it?Testing
Testing
Testing -
Have you tried to install from a usb thumbdrive instead? I hear that works well. In fact Dell has Ubuntu and XP on thumbdrives to ship to people without optical disc drives. You have to request it from technical support. I'm not sure if the XP thumbdrive is still in stock or not, I couldn't find it in the system.Main Surround -
I had this same problem and did some research.
You need to restore your pc hardware and bios settings back to factory defaults.
This means disconnectiong any extra hard drives you might have installed and also deactivating same in bios.
This means reducing RAM back to original amounts and setting that in the Bios. On many you can't reinstall when ram is over 3gb. After reinstall you can go back and add back in your HD and ram again with no issue.
After I disconnected my HD and reduced the RAM I was by the 33 minute hangup.
This was my experience and YMMV.
GL
RichAnalog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
His netbook can't even support over 2gb, so the 3gb limit on windows install isn't an issue (there's also a switch on install you can use to bypass this anyways).
As far as changing stuff back to stock, there isn't much you can change on a mini9 that will cause his issue.Main Surround -
I havent even messed with it. If I have time, I'll try some more tomorrow. It has been sitting like this for a couple months because I havent had time to play with it.
You can send it to me and I'll fix it
I'm DCSE certified among other things (not that it matters).Main Surround -
I talked to dell yesterday...they said to send it in as it sounds like a hardware problem.You can send it to me and I'll fix it
Well, it doesnt say what they did...but it works now!
That's what you wanted! Glad it's all worked out now.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
That works! Let me see what they did...
they just replaced the hard drive with an imaged one.
seems easy enough.Main Surround -
