2005 Tacoma Radio problem
Vette C6.r
Hey guys, I need some help with a wierd problem. I have a 05 Tacoma and the factory radio keeps changing channels. The problem comes and goes and usually only moves the FM dial .2 off the designated channel but sometimes it just goes crazy and moves up and down quite a bit.
Anyone else have this problem. I have checked wiring and the antenna hook-up, all are tight and not frayed.
Is this a problem with the radio or something else. i.e the control knobs on the steering wheel.
Thanks in advance.
Tony
Thanks in advance.
Tony
Post edited by Vette C6.r on
No idea of whats causing the problem, but one solution would be to upgrade the hu. Swap the factory hu with a good alpine, pio, kenwood, eclipse unit. That would be a start. You can then see if you want to upgrade the speakers as well.
X2 upgrade the hu and when you do slap in a pac swi so you can keep the steering wheel controls. I don't know you may even get better reception with an aftermarket hu.
Been to the Toyota forum? They have a rabid fan base...much like here. Club-Toyota....Toyotanutz....PM Shawn474.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Yep, sure do, and they never stop with it. They just keep going, like a juggernaut, completely unstoppable...
concealer404 wrote: »Yep, sure do, and they never stop with it. They just keep going, like a juggernaut, completely unstoppable...
Just like my Toyota keyboarrrrrrrdddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddd.... -
Thanks Doro. Just trying to avoid another addicting website.
I guess another recall is in order !!!!!!!!!!!
Damn Toyota's -
Yusss!!!! Someone got it!
But seriously Tony, check out Toyotanation.com. I'm sure you're not the first to experience this, and there's a lot of handy people over there. They may be able to help you out. Sorry to hear about the diminished quality in new Toyotas.
I'll stick with my 90s models.
Thanks guys. I posted it on Toyotanutz. What's up with the regulars wandering off to the car audio section ????
I read over here from time to time... don't post a whole lot, since i haven't really done any major installs in years...I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Waaaaaaa! Hahahaha! Funniest thing I've heard all week!Just like my Toyota keyboarrrrrrrdddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddd....
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
You may be able to do what I did and drop a Scion HU in there, I have a 2004 4Runner, and the Scion was a direct replacement. If it'll work for you, I'd recommend it as it's a HUGE improvement over the stock Toyota radio, don't ask me why they made the decision to put a better radio in a cheaper car.
I don't know if they're all the same, but but actually has Pioneer Premier on the white label on top, it's a MUCH better HU than the stock radio. I have the T1804 in mine, but I believe there are newer models with more native iPod support. -
As for your problem, I would check the wiring harness that plugs into the back of the radio, check to make sure that it's plugged in all the way (probably is) and check to make sure that there are no loose wires within the harness itself (more likely)
I don't know about flashier, it actually looks stock in my 4Runner, but it sure sounds better. I do think the newer models are a bit flashier though and allow you to change colors and such
Been to the Toyota forum? They have a rabid fan base...much like here. Club-Toyota....Toyotanutz....PM Shawn474.concealer404 wrote: »Yep, sure do, and they never stop with it. They just keep going, like a juggernaut, completely unstoppable...
How rabid? Is it more or less than the ED forum?
