SDA magnetic shielding
Vette C6.r
Vette C6.r Posts: 1,560
edited February 2010 in Vintage Speakers
Hey guys. I finally have some $$$$$$$$$ to play with when the taxes come back. I will be in the market for some SDA's. My question is in regards to magnetic shielding. I plan on incorporating the HT and the 2 channel. The SDA’s would be on either side of my TV. All my previous speakers have been shielded so this was never an issue that I worried about. Will this cause any harm to the TV ??? Aside from the obvious distortion of the TV picture is there any other “hidden” problems that may arise that aren’t visually obvious ??? If there is a problem is there anyway to "shield" them because I would really like to have them placed on either side of the TV
I have a Samsung 67” LED DLP if that matters.
Thanks guys.
Cheers.
Tony
Post edited by Vette C6.r on
  • Disc Jockey
    Disc Jockey Posts: 1,013
    Shouldn't be an issue with a DLP. The magnetic shielding is needed for CRT sets.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • thsmith
    thsmith Posts: 6,082
    I have my 1Cs on either side of my Mits 73" RPCRT and have no issues
  • Conradicles
    Conradicles Posts: 6,343
    Correct on that one. You should have no issue.
  • Vette C6.r
    Thanks for the quick replies. My other question was do you guys know if there is any "hidden" harm that may go unnoticed or is the visual distortion the only negative effect.
  • bluecomet
    bluecomet Posts: 1,118
    There should not be visual distortion with a DLP or LCD. It is only an issue with CRT sets.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • Vette C6.r
    Excellent, thanks guys !!!
