Computer guys - hard drive question
  • mhmacw
    mhmacw Posts: 832
    edited February 2010
    ben62670 wrote: »
    Mounting a hard drive on it's side doesn't hurt anything. HP's and Compaq's did this a lot. A lot of servers with hot swaps are on there side.
    indeed. the orientation of the drive itself is varied. the cooling system is designed around the orientation not vise versa meaning there isnt one cooling pattern for all mounting orientations
  • snow
    snow Posts: 4,358
    mhmacw wrote: »
    man i didnt call any body and idiot. if someone has the experience that has been portrayed then it should have been obvious to the most casual observer what my reference was. to respond in a fashion that implies my post made no sense shows either ignorance of indifference. neither of which is respectful and could in most cases be considered disrepectful given your position. i 've taken your advice and searched names vs. pics vs. screen names and really all i have to say is there isnt one of "yall" that would speak to me face to face as you speak to me here. fabricate text as you will and make the story up as you go along but its in the type and its undeniable. sorry to have ruffled the echelons feathers that wasnt my intention. ultimately my position stands... if you mount a piece of equipment in a fashion different than designed you may run into performance issues. specifically cooling.
    Have you been drinking again? Just curious because it seems you have been awfully angry over some very little things. And what the hell does pics and screen names have to do with speaking to you differently face to face?
    REGARDS SNOW
  • mhmacw
    mhmacw Posts: 832
    na its sunday. i dont drink on sunday. im not sure what your saying in the rest of that
  • ben62670
    ben62670 Posts: 15,969
    No cooling system to really speak of except vents in the front and just the PS fan pulling the heat out of the case. I have built, repaired more computers than I care to remember. Have fun.
    Ben
    Ben
  • mhmacw
    mhmacw Posts: 832
    ben62670 wrote: »
    Ben
    im sure then you know a fan is part of a cooling system. scattered a few on the bench my self
  • snow
    snow Posts: 4,358
    mhmacw wrote: »
    This what you said in an earlier post.
    (i 've taken your advice and searched names vs. pics vs. screen names and really all i have to say is there isnt one of "yall" that would speak to me face to face as you speak to me here.)
    I was curious as to what the hell does pics and screen names have to do with how someone would talk to you.
    REGARDS SNOW
  • mhmacw
    mhmacw Posts: 832
    in my experience folks dont seem to have as much to say face to face. or if they do it has a bit softer tone if you will.
  • snow
    snow Posts: 4,358
    mhmacw wrote: »
    LMAO True enough. But dont let pics fool ya some of the smallest skinniest guys are double tough, remember Bruce Lee? even short fat ones can surprise ya ;)
    REGARDS SNOW
  • mhmacw
    mhmacw Posts: 832
    snow wrote: »
    REGARDS SNOW
    there was a buddy of my dads that weighd 155 lbs. he was a golden goves . he could hit the speed bag and knock it off the hook.
  • Systems
    Systems Posts: 14,873
    Amherst wrote: »
    Not so sure...... but, my DVR throws a ton of heat (hotter than my AVR).
    Could probably cook pancakes on it.
    The heat dissipation from the electronics may cause component overheating, possibly hard drive also, if turned on side. I wouldn't consider it an option with my unit. What type DVR are we talking here? YMMV
    Hopefully it doesn't look like this inside:)
    http://www.wkblog.com/tivo/2010/02/beyond-description-nasty-tivo/#comments
    Testing
    Testing
    Testing
  • nguyendot
    nguyendot Posts: 3,594
    If you mount it on it's side, mount a rotisserie on it and light up some ribs! It'll be hot for sure.
    Main Surround -
  • Amherst
    Amherst Posts: 695
    Lorthos wrote: »
    I thinkin after the board burns up and it sits idle for a while... Yea. :D
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
  • edbert
    edbert Posts: 1,041
    There are no fans in this unit actually. The whole top and sides are vented. The bottom, front and back panel are all sealed off. I found a couple pictures. One of the guts and the other with the case on it.
    Either way, this is a brand new box since my previous one died Saturday. And no, the one that died was not because of hard drive failure, something on the board finally went kaput. I was having intermittent problems and had a tech out Friday and he mentioned he thought the DVR was causing the problems and that he thought it would be going out sometime fairly soon. I waited to get him to change it out because I was going to try to get a few programs saved off the hard drive before getting it switched out and it died 24 hours later. AT&T came through and had a tech out Sunday afternoon to deliver my new box and make sure everything worked.
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • dorokusai
    dorokusai Posts: 25,576
    I wouldn't hesitate to put that unit on its side, HDD up for example.
  • mhmacw
    mhmacw Posts: 832
    +1 on that. the full perforation on the top cover allow for convection and no "pocket" at the top to trap air.
  • dorokusai
    See, we CAN agree ;)
  • edbert
    edbert Posts: 1,041
    In my case, I actually have the hard drive down because of where the remote sensor is. If I had it on the other side I would have to raise the TV another inch or two and I really don't want to have to do that.
    Glad to see you two dorks can get along!!!! Have a nice day fellas.
    Pioneer VSX-816
    CS1 - center
    XBOX
    SOPA since 2008
    Here's my stuff.
  • dorokusai
    I don't believe it will be a problem either way given all that free air available for the heat to rise thru the unit.
  • mhmacw
    mhmacw Posts: 832
