Need speaker advice
booboo
booboo Posts: 7
edited February 2010 in Speakers
I have a 2003 F150 Supercrew with a AVIC F700BT. I would like to replace the speakers because the stock ones suck. I am not going to buy an amp, subs or component speakers. I would like a speaker that will give me a big sound improvment. I like to crank up metal, rock, country and rap on occasion and listen to talk radio the rest of the time. I was considering the DB571s as I was told they handle low power (no amp) situations well. Is this a good match or is there something better?
Post edited by booboo on
  • NJPOLKER
    NJPOLKER Posts: 3,475
    Wrong section. You will be best served going to the "On The Move" car audio section.
  • booboo
    booboo Posts: 7
    You are right. I posted there. Sorry
  • headrott
    headrott Posts: 5,496
    booboo wrote: »
    It's all right, you just made a little.........OK stupid joke I know.:D
