Need speaker advice
I have a 2003 F150 Supercrew with a AVIC F700BT. I would like to replace the speakers because the stock ones suck. I am not going to buy an amp, subs or component speakers. I would like a speaker that will give me a big sound improvment. I like to crank up metal, rock, country and rap on occasion and listen to talk radio the rest of the time. I was considering the DB571s as I was told they handle low power (no amp) situations well. Is this a good match or is there something better?
Post edited by booboo on
Wrong section. You will be best served going to the "On The Move" car audio section.
You are right. I posted there. Sorry
It's all right, you just made a little.........OK stupid joke I know.:D
