joining the tubers
BAD ASP
BAD ASP Posts: 361
edited February 2010 in 2 Channel Audio
well I let myself get talked into a small foray into 2 channel tubes. I bought a small tube pre to check out the old school stuff. I will be using a sunfire 2 X 300 amp with a pair of modded lsi9's. Ben is helping me out with the speaker XO mods. Once I get those back I'll render a very humble opinion. Thanks to George G. for some advice and support.
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner
Post edited by BAD ASP on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    CoooooooooooooooooooooooooooooooooooooooooooooooooooooooL :D
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • NJPOLKER
    NJPOLKER Posts: 3,474
    Good job and good move on the guys you chose to assist you.
  • concealer404
    concealer404 Posts: 7,440
    What are all those pieces?
  • leroyjr1
    leroyjr1 Posts: 8,785
    Thanks George !!!!!!!!!!!!
  • doctor r
    doctor r Posts: 837
    George helped by gently nudging you over the edge into the rabbit hole. Alice is waiting at the bottom but the journey down is long. Welcome to the wonderful world of cathodes, anodes, grids, and plates all packaged into a nice glass bottle. The sound can be addicting so quickly aquire a local support group or councelor that can eventually inititate the intervention when it is needed. Congratulations! I love my tubes:).
    Rick
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • BAD ASP
    BAD ASP Posts: 361
    I bought these pieces as part of a complete system and admittedly don't know the pieces yet. I wanted the pre and the rest of the system is a wpp200c and power supply which is for a turntable. Additionallly there is a step up which someone is going to have to explain to me. Unfortunately the system did not come with a manual so I will need some help with set up to be sure. I am looking forward to it. My wife has quite a collection of albums from the 60's and 70's. I don't know what condition they are in but we'll see. I have some albums I bought and never opened. Cream Wheels of Fire, Disraeli Gears, All of Jimi Hendrix albums as well as some oddballs, Vanilla Fudge and such. I do need to get a turntable so suggestions are welcome.
    Rears: Polk LSiFX
  • organ
    organ Posts: 4,969
    Bad ****!!! Enjouy your tubes man!
  • doctor r
    doctor r Posts: 837
    The step up is placed between the phono cartridge and the preamp. If it is just a step up then it most likely has two transformers in it to boost the very low voltage output of a moving coil cartrige up to one that a normal preamp moving coil input could be able to use. Low output moving coil cartridges voltage can be 0.25 millivolts up to 0.9 millivolts while most moving magnet cartridges were designed to put out 3.0 to 5.0 millivolts. The box will "step up" the voltage to one the preamp can use it.
    rack Adona Eris 6dw
  • doctor r
    doctor r Posts: 837
    If you do not employ or purchase a low output moving coil cartridge you may not need the step up initially, though this gives you great flexability to try alot of cartridges in the future.
    Rick
    rack Adona Eris 6dw
  • george daniel
    george daniel Posts: 12,096
    The Wright phono has enough gain for mm carts,, if he chooses a lo output mc,he will most assuredely need the step up.Nice snag.
    treitz3 Posts: 19,999
    Welcome to the club. Have fun! ;)
