Are there any decent sheap sub EQ's
  • bevo
    bevo Posts: 306
    edited February 2010
    I wish I did have the time, and I thought I did, until the other night when I found out my 3 year old doesn't like listening to loud test tones for hours on end.
    I got rid of the null when I moved my sub to the center of my longest wall without an opening to it. I finally tried the sub at the LP and it worked.
    I still would really like to learn REW, but I think that might have to wait until my little boy gets a few years older and my wife is out of school.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
  • DMara
    DMara Posts: 1,434
    Not for nothing, but your Denon 1909 has Audyssey MultEQ XT, which should do a pretty good job of EQ'ing your SVS (though not with the higher resolution that the standalone SVS unit does). Just turn your subsonic filter off on the subwoofer before you run Audyssey, do all available positions, then re-enable the subsonic filter. The slope of the filter causes Audyssey to boost deep bass, whereas running it without the filter gives Audyssey an idea of the sub's actual -3dB point, then the filter can do what it's supposed to post-Audyssey.
    For the PA microPro 4000 and 1000, is there a subsonic filter switch/tuner?
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • thsmith
    thsmith Posts: 6,082
    bevo wrote: »
    I understand. I invested a lot of time learning REW and I was using 1 true sub and 2 mid-bass modules. It helped me finally get an SVS PB13.
    REW allowed me to EQ the 13 using just the one filter built into the sub, luckly that is all I needed or I would have kept the BFD which is a great product. Since my sub was already EQed and when I run Audessy my sub and mains are matched perfectly. That was over a year ago and have not had or wanted to touch my sub settings.
    Before it was daily and driving me nuts.
    Good luck and protect the little guys hearing above all else in audio.
    treitz3 Posts: 20,038
    DMara wrote: »
    No. The subsonic filters are likely found on your pre.
  • bevo
    bevo Posts: 306
    I ended up getting the SMS-1. It came today and I got my sub as falt as possible, The largest dip or peak from 15hz to 80 hz is only 2 or 3 db. It's sounds great with HT, but it doesn't sound as good as it did before with music.
    I plugged in the SMS-1 one and got everything flat, but I did it after running audyssey.
    Should I turn off audyssey, and run manual eq, do the SMS-1, and after I get everything straightened out, then run audyssey.
    One thing that was weird was that I had to lower my filters in the 65hzand above range to get a boost. If I tried and boost at that frequency it actually lowered my db. everything worked in reverse at those frequencies.
    I read the outlaw audio manual, and pretty much followed it to a T. Any advice anyone has would be great. And if anyone knows an easy way to get a house curve without having to move all the filters, that would also help me a bunch.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Audyssey should be ran by itself, just as the SMS-1. Try it with just the SMS-1 and see how your music takes form.
    You don't ever want to double up on the active crossovers. That leads to bad ju-ju...
  • bevo
    bevo Posts: 306
    I think I've learned something. A flat sub sounds very bad, or I guess I should say, it does not sound good to me. I need to just run audyseyy and help out the curve it sets a little with my SMS-1. I'm going to need a quite house for that though, and with a 3 year old boy in the house, that is very hard to come by.
    I really think I jumped the gun on the SMS-1, and really didn't need it. I guess I'll find out tonight when he is asleep, if not I'm going to take him to daycare for a few hours tomorrow and have the house to myself and give it a go.
    I really think there might be a very slightly used SMS-1 in the for sale section by the end of the weekend.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Are you setting up just the sub or the mains and the sub to the room?
  • bevo
    bevo Posts: 306
    While I'm doing the SMS-1 I have the mains on and have them crossed at 80 and the sub at 80. I've tried different crossover points, but they seem to make no difference. So far just running audyseyy without The sms-1 sounds the best.
    I run the SMS-1 with the receiver on manual eq, and I can get an lmaost perfectly flat graph all the way acrossed. Then I play some music and the sub is very, very low. I kind of assume that's how it's suppose to be.
    When I run audyseyy without the SMS-1 anywhere involved I get about a 16db curve to 100hz and it's sounds great. Really all I wanted to do with the SMS-1 was tame a 50hz peak and try and boost a 70 hz dip. When I do that though, everything sounds awful. It's just to flat.
    I read at Home theater shack on how to determine your house curve. Hopefully I can get some time tomorrow, to try and figure that out. Really though I think audeseyy by itself was doing alot better job then I thought.
    Nice flat graphs look really cool and all on the screen, but they just sound exactly what their called, flat.
    I think I'm going to take it to a buddies house saturday also. He doesn't have any kind of self calibrating EQ on his AVR. The SMS-1 could probably really help him out. Hopefully it sounds great on his system and he hands me about 350$. I would love to put that into another part of my system after seeing how well my AVR did everything without any help. Maybe another set of FXI's to complete my speakers.
    I guess that sometimes learning a new hobby might end up costing some money you never needed to spend.
    Who knows though, maybe once I get the house to myself, I can play some test tones, and really figure out where everything needs to be.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • bevo
    bevo Posts: 306
    After more, and more testing. Audyseyy does as good of a job without the sms-1.
    final verdict. I wasted 350$
    If I wouldn't have been able to move the sub to where it is now, The SMS-1 would have helped me a bunch, but I seem to have found a sweet spot, and the only problem was a big 50 hz spike that I took care of with the subs PEQ.
    So anyone looking for a week old SMS-1 may be able to get one if my buddy doesn't want it. He doesn't have audyseyy, so it would really help him out, but I don't know if he'll be willing to shell out any cash for it.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
