Is a new sub really needed?
Well I have my new system all setup. It sounds great. For the longest time I was fretting over needing a new sub, but the one that I have sounds great. I wonder if I just do not know what I am missing????
Your opinions?
Your opinions?
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
Monster HTS 3600
Post edited by chiptouz on
Do you have any experience with better subs?
IMO a new sub would be a nice upgrade.Pro-ject RM-9.1 w/ Grado Sonata 1 -> USP-1 -> RPA-1 -> Vienna Acoustics Mozart Grands -
upgrades are always good.. that is if you are not happy with what you have.
I would try to go to some local shops and take a listen to different subs and see if one grabs your attention. If you are happy with what you have why change?
Unless you have money that is burning a hole in the pocket and in that case I will be sending you a list of things that I could use. J/k good luck with your search and remember its your system and you are the one that needs to be happy with it.
MarkSig to be updated after dealing with the insurance company:(:(:( -
It's a case of not knowing what you're missing.
I'm sure the PSW350 is a decent sub...but the Polk PSW series isn't exactly a high end sub. Until the DSW series came out, Polk's subs have generally been sub par IMO. The PSW505 is the gem of the pre-DSW series subs though.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I like my PSW350, but I did plug one of the ports with a rubber cup (plumbing temp plug type) and it hits deeper and cleaner, a least IMO. But I have Mon 10b's, so about the only time I even hear/ notice the sub is watching movies, for those 'big' sound effects...like in Terminator I watched last night...:D
But then again, there are some awesome new subs out there. -
It is absolutely needed. Your life is incomplete without it.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thanks for the replies. I appreciate it.Sharp LC-80uq17u
Monster HTS 3600
