Subsonic Filter
Systems
Is there such thing as a subsonic filter that i can buy that I can put somewhere in the line before the amp? I'm looking to make a ported box with my Kappa Perfect 10.1d and giving it 320wrms and I'm afraid to use it without a subsonic filter
Testing
Testing
Testing
Testing
Testing
yes... the following companies i know make them... other's do as well, i'm just not too informed on them all as i stay away from ported boxes (not that i dont like ported, just never bought a sub that i'd wanna port).
most subsonic filters are incorporated into a pre-amp crossover / bass boost / subsonic filter device (some have equalizers on them too).
-- audiocontrol
-- eclipse
-- sony
-- pyramid
-- profile
i believe fosgate does as well.
mtx does not.The Artist formerly known as PoweredByDodge -
Yikes... These definately aren't cheap. I'm guessing I wont find one for under $50? I'll look some more. Thanks for the helpTesting
Testing
Testing -
if u can get one for 50, you're either sleeping with the right guy/girl, got stock in the company, or are really good at online shopping.
if u get one for 50 - and its decent - jump on it.The Artist formerly known as PoweredByDodge -
nexxon.com has one by Harrison labs...30 bux..good luck
