Subsonic Filter
Systems
Systems Posts: 14,873
edited October 2003 in Car Audio & Electronics
Is there such thing as a subsonic filter that i can buy that I can put somewhere in the line before the amp? I'm looking to make a ported box with my Kappa Perfect 10.1d and giving it 320wrms and I'm afraid to use it without a subsonic filter
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited October 2003
    yes... the following companies i know make them... other's do as well, i'm just not too informed on them all as i stay away from ported boxes (not that i dont like ported, just never bought a sub that i'd wanna port).
    most subsonic filters are incorporated into a pre-amp crossover / bass boost / subsonic filter device (some have equalizers on them too).
    -- audiocontrol
    -- eclipse
    -- sony
    -- pyramid
    -- profile
    i believe fosgate does as well.
    mtx does not.
    The Artist formerly known as PoweredByDodge
  • Systems
    edited October 2003
    Yikes... These definately aren't cheap. I'm guessing I wont find one for under $50? I'll look some more. Thanks for the help
    Testing
    Testing
    Testing
  • PoweredByDodge
    edited October 2003
    if u can get one for 50, you're either sleeping with the right guy/girl, got stock in the company, or are really good at online shopping.
    if u get one for 50 - and its decent - jump on it.
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited October 2003
    nexxon.com has one by Harrison labs...30 bux..good luck
