DIY Record Cleaner with a Technics TT
Toolfan66
Well I thought this should have it's own thread. I got a Technics Turntable that I am turning into a Record Cleaning Machine. Now I know I will get some crap for doing this to this table but I could care less:cool: I have been looking for a TT on the cheap to give this a shot, and low and behold I got 2 of these TT's for $30 so this project is costing me very little to try out.
As you can see I have taken out the Tonearm and put in place a piece of plastic that I turned on the lathe. I also went to home depot for some PVC parts to make a couple of pickup tubes. you can also see on the bottom where the vacuum will hook up to.
I am also building a cabnet at work that will have a door on the front to house the cleaning supplies and vacuum, it will also have a piece of smoked plexiglass for the top to cover it. I will post pics as it gets under way.
I have a ways to go but this will give you an idea.
Post edited by Toolfan66 on
Wow really cool project Larry. You may want to consider using delrin for the vacuum tube. This way you won't have to place any velvet or felt on the underside to protect the record. The delrin being a first cousin to vinyl can make contact with the record without damaging it.
Just a thought. -
hearingimpared wrote: »Wow really cool project Larry. You may want to consider using delrin for the vacuum tube. This way you won't have to place any velvet or felt on the underside to protect the record. The delrin being a first cousin to vinyl can make contact with the record without damaging it.
Just a thought.
Thanks!! I did not know that, I will look into it for sure. -
You might also want to consider removing the Direct Drive motor from below the platter and fitting it with a belt driven setup so as not to create a deadly combination similar to a toaster in the bathtub.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
You might also consider selling your original Technics TT for several hundred dollars to someone who will actually appreciate it, and buying a real record cleaner.Ludicrous gibs!
nooshinjohn wrote: »You might also want to consider removing the Direct Drive motor from below the platter and fitting it with a belt driven setup so as not to create a deadly combination similar to a toaster in the bathtub.
Not worried about it I will have the underside of the platter sealed , plus it's not like I will be pouring the cleaning solution all over the place. -
You might also consider selling your original Technics TT for several hundred dollars, and buying a real record cleaner.
Yeah i figured a comment like this would come along. God forbid someone just have a little fun in this hobby and try doing things for the hell of it.:rolleyes:
Not that it matters but I gave the other TT to Ben knowing I could have sold it for a couple hundred. Money is not the issue here having fun is. if it works great if not I plan to buy a RCM.
Peace. -
TOOLFORLIFEFAN wrote: »Yeah i figured a comment like this would come along. God forbid someone just have a little fun in this hobby and try doing things for the hell of it.:rolleyes:
A real record cleaner will make the LP's played on your Fisher Price "My First Record Player" sound much better.
Why would you use a TT valued at several hundred dollars for this project, instead of getting a throwaway and destroying that? I don't care what you paid for the TT's from the Goodwill or wherever... the point is you're destroying a GOOD turntable.
Building your own LP cleaner? I have no problem with that! The more the merrier... just don't destroy a good, valueable TT to do it. Maybe yours and my opinions of valueable differ. You already gave one of these away, after all.Ludicrous gibs! -
The thing is if it don't work all I have to do is solder one wire put the tonearm back in and what do you know a TT that works just as it did when I took it apart. it's my TT anyways why the hell would you care? -
+1
+2
+3
I cannot agree with this project at all. -
I don't believe I was out asking for anybody to agree with it. Im having fun with it so thats all that matters. and like I said I can always put it back together in the end.
Have fun Larry. I am just glad you did not use that Rega;)
That will be one fine RCM when your done.
Need any Triton X-114, it is a surfactant?Speakers: SDA-1C (most all the goodies)
I would have never used that Rega, That i would have put in the rig.
Does the Triton work well? I don't know much about it. -
Peace.
Having fun in this hobby is absolutely NOT allowed! This is a serious hobby equally important to saving the baby seals and preventing global warming.
:D The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Works great for me and I have given to others here and a couple of friends and they seem to like it.
I empty out 16oz of distilled water, add 16oz of alcohol and 3-6 drops of Triton. Records sound great and I never find build up on my cart using a microscope.
http://www.teresaudio.com/haven/cleaner/cleaner.htmlSpeakers: SDA-1C (most all the goodies)
That is going to be the sexiest LP cleaner around....nice job on the 'bushing'
Can I hire you to make me one, when the time comes? Unless of course I have a lathe by then.....
FYI: there is some great links in the thread about Ben building his... (started with someone giving the TT to him) I tried to find it but gave up after looking back 12 pages of his post...sorry I thought I had it 'bookmarked'
One of the links talked about remote locating the vacuum, to get rid of the 'jet engine'.
Might be something to consider...I am definitely doing that...
It'll be nice to see what else you 'innovate' -
Larry,
You can get a bottle of VPI record cleaner concetrate for $20 bucks, add it to a gallon of distilled water and be done with it. I like Tracy's idea but I don't like the idea of alcohol in that ratio going onto vinyl. I know Tracy has had luck with his but I don't know I just recoil from that much alcohol.
http://www.audioadvisor.com/prodinfo.asp?number=VPRCMCON
You might be able to get it cheaper elsewhere.
I use the VPI cleaner before I play each record and it doesn't require a rinse.
Just my humble opinion. -
Cool Project!!!!!!!!!!
I was sitting here thinking about doing the same thing. I've got an old Garrard with 16, 33, 45, and 78 speeds on it. That way time constraints would all but be eliminated if I were pressed for time in cleaning. MORE Power, faster, faster.
I do have a VPI cleaner but I love the looks of homebrew and the idea of a bit of ingenuity.
Harry -
Found the link I was looking for
http://www.polkaudio.com/forums/showthread.php?t=93242 -
Came in the mail yesterday.;)
Cool it's nice to know that there is more than empty space on the internet! LOL!!!:D
Today I got a chance to get this off the laser, formed, and tack welded together. With this project and my 1C's I have my hands full.
We are so busy at work I don't get the chance to run some of the things I want to as my job is to keep the jobs going out the door. it's hard to run things that are not making the company money. as a mater of fact I have to work all weekend as well.But I am going to get to work early in the morning to weld and grind my cabnet so I can send it to paint next week.
I will have a smoked lexan top that will cover it when not in use as well as a shelf inside the door for my cleaning products.. -
WoW! That's looking killer, Larry. Hurry up and finish it. I can't wait to see how this turns out. What color are going to paint the cabinet?
Thanks!! Not sure about the color yet, I will be giving Brad a visit at the paint shop to see what he has. I am thinking just a Black or White.. -
looks great man!
Larry, that is friggin awesome and really pretty too. You're a talented guy buddy.
brushed black anodized finish with some cool etchwork on it would look great. Fantastic work Larry!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Nice sheetmetal work. Are you going to mig or tig it? I used to program a laser back in late 80s-early 90s using APT. Lots of fun for all.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Polkersince85 wrote: »Nice sheetmetal work. Are you going to mig or tig it. I used to program a laser back in late 80s-early 90s using APT. Lots of fun for all.
Thanks!! I will tig it,for one it's fun second it's a lot easier to grind..;) -
Cool, keeping it simple...Is it completed enough to do any cleaning yet?
I could if I hooked it all up but I will wait till it's all done.;)looks great man!
Thanks Kevin, so how are things out your way? PM me..hearingimpared wrote: »Larry, that is friggin awesome and really pretty too. You're a talented guy buddy.
Thanks Joe!! I am looking forward to getting it up and running maybe by next weekend. You know I will post some pics when it's done.nooshinjohn wrote: »brushed black anodized finish with some cool etchwork on it would look great. Fantastic work Larry!
This is 16 gauge steel, you can only anodize aluminum. I am sure I will just go with a Black Smooth Or Black Texture powder coat. -
Man that looks nice! Glad to see that your having fun with this. What are you going to use for your vacuum supply?
I'd love to have you build me a cabinet for my VPI 16.5 cleaning machine
:D Carl -
Great looking work.engtaz
