1C and 1.2tl Tweeters
JayCee
Hi all,
I have a pair af 1Cs and 1.2tls and am looking to upgrade the tweeters on both to the RDOs with mod's to the XOs at a later date. I've searched the site and am pretty sure of the answer, but want confirmation for the following:
Can the SL3000 be used on the 1Cs so I can upgrade both now, starting with the 1.2tl and incrementally doing the 1Cs from the SL2000 to SL3000 and finally RDOs? I beleive it's no without totally changing the XO, and if so, can and should I do a TL mod to the 1Cs?
Thanks in advance for any help.
John
John
➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Post edited by JayCee on
Pretty sure that is not an approved mod. As far as I know the 1C's can not be TL modded.
They do sound signifigantly better with updated tweeters and upgraded capacitors/resistors.
Enjoy!:) -
No. You want either the SL2000 or its replacement, the RD0194-1.can and should I do a TL mod to the 1Cs?
As Conradicles stated, there is no TL mod for the 1C's.Political Correctness'.........defined
President of Club Polk -
Okay, as I thought, just wanted to confirm.
Thanks to you both,
John➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Which speakers are the RDO198's for?____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Any SDA or RTA that has TL in the model designation. It is also used to replace the SL2500 tweeter.Political Correctness'.........defined
OK. So since the 1C cannot be TL Modded, the only replacement tweeter is the RDO194, correct? sorry, didn't mean to hijack your thread.____________________________________________________________
yep SDA 1C's ----RDO 194JC approves....he told me so. (F-1 nut)
