1C and 1.2tl Tweeters
JayCee
JayCee Posts: 1,500
edited February 2010 in Vintage Speakers
Hi all,
I have a pair af 1Cs and 1.2tls and am looking to upgrade the tweeters on both to the RDOs with mod's to the XOs at a later date. I've searched the site and am pretty sure of the answer, but want confirmation for the following:
Can the SL3000 be used on the 1Cs so I can upgrade both now, starting with the 1.2tl and incrementally doing the 1Cs from the SL2000 to SL3000 and finally RDOs? I beleive it's no without totally changing the XO, and if so, can and should I do a TL mod to the 1Cs?
Thanks in advance for any help.
John
Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Post edited by JayCee on
  • Conradicles
    Conradicles Posts: 6,134
    JayCee wrote: »
    Pretty sure that is not an approved mod. As far as I know the 1C's can not be TL modded.
    They do sound signifigantly better with updated tweeters and upgraded capacitors/resistors.
    Enjoy!:)
    F1nut Posts: 50,753
    No. You want either the SL2000 or its replacement, the RD0194-1.
    As Conradicles stated, there is no TL mod for the 1C's.
  • JayCee
    JayCee Posts: 1,500
    Okay, as I thought, just wanted to confirm.
    Thanks to you both,
    John
  • dpowell
    dpowell Posts: 3,068
    Which speakers are the RDO198's for?
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
    F1nut Posts: 50,753
    Any SDA or RTA that has TL in the model designation. It is also used to replace the SL2500 tweeter.
  • dpowell
    OK. So since the 1C cannot be TL Modded, the only replacement tweeter is the RDO194, correct? sorry, didn't mean to hijack your thread.
  • george daniel
    george daniel Posts: 12,096
    yep SDA 1C's ----RDO 194
