1C and 1.2tl Tweeters
JayCee
JayCee Posts: 1,509
edited February 2010 in Vintage Speakers
Hi all,
I have a pair af 1Cs and 1.2tls and am looking to upgrade the tweeters on both to the RDOs with mod's to the XOs at a later date. I've searched the site and am pretty sure of the answer, but want confirmation for the following:
Can the SL3000 be used on the 1Cs so I can upgrade both now, starting with the 1.2tl and incrementally doing the 1Cs from the SL2000 to SL3000 and finally RDOs? I beleive it's no without totally changing the XO, and if so, can and should I do a TL mod to the 1Cs?
Thanks in advance for any help.
John
Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Post edited by JayCee on
  • Conradicles
    Conradicles Posts: 6,377
    JayCee wrote: »
    Pretty sure that is not an approved mod. As far as I know the 1C's can not be TL modded.
    They do sound signifigantly better with updated tweeters and upgraded capacitors/resistors.
    Enjoy!:)
    F1nut Posts: 52,002
    No. You want either the SL2000 or its replacement, the RD0194-1.
    As Conradicles stated, there is no TL mod for the 1C's.
  • JayCee
    JayCee Posts: 1,509
    Okay, as I thought, just wanted to confirm.
    Thanks to you both,
    John
  • dpowell
    dpowell Posts: 3,081
    Which speakers are the RDO198's for?
    F1nut Posts: 52,002
    Any SDA or RTA that has TL in the model designation. It is also used to replace the SL2500 tweeter.
  • dpowell
    OK. So since the 1C cannot be TL Modded, the only replacement tweeter is the RDO194, correct? sorry, didn't mean to hijack your thread.
  • george daniel
    george daniel Posts: 12,096
    yep SDA 1C's ----RDO 194
