Which Polk center channel speaker is this???
I have this Polk center channel speaker but cant figure out for sure which model it is.
It measures 12-3/4" wide x 9-1/4"" deep x 6-3/8" tall.
It has a 1" dome tweeter and two 5.25" drivers.
It is like a CS245i but with different drivers.
Your help is appreciated.
"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life."
Post edited by TNTsTunes on
Are you sure it isn't wider than 12 3/4" wide? I don't think that is the right size, as just the drivers are wider than that.
My 'guess' it is a CS245 (no "i") same as the CS245i, but the older grey drivers.
That IS the closest, match.. -
I meant to type it is 16-3/4" wide... It measures the same as a CS245i so I bet you are correct.
I just searched more and found the CS245 tweeter is a silk dome just like mine has.
Thanks for your response and spotting my typo.
a man on fire and he'll be warm for the rest of his life." -
That would be my guess.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
