Ambient light options?
themuskr
Hey all, I was just wondering if there are any cool ways to create some ambient light around my TV. i have seen some behind tv lighting systems, but i was just wondering what others have done.
Sorry if this is in the wrong forum.
thanks-
thanks-
2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
Pioneer Elite vsx-40
BJC cable
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable
Post edited by themuskr on
Ikea has Dioder LEDs that look good - check out DH4645's set up in the system showcase...
I use a Cinema Quest "Ideal Lume" 6500 kelvin lamp. Makes quite a difference, especially at night.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
A blacklight on either side has always done the trick for me.
I've also got a blacklight mounted behind each of my speakers. Makes for some great ambiance, when mixed with my numerous posters.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
For some reason, I am hearing **** music in my mind reading this.
--Gary--
I had an Idealume behind my old RPTV, but it didn't work well with my projector screen when I stepped up. I snagged a couple of little LED accent lights from Home Depot and stuck them to the back of my armoires with double-sided tape so that they light up the walls to the sides of the screen. Works quite well, and was cheap.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
These are pretty slick
http://www.amazon.com/Cyron-LED-Lighting-Pack-System/dp/B000V1NW7G/ref=sr_1_1?ie=UTF8&s=hi&qid=1265761415&sr=8-1(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
(2) Panny DMPBDT110 3D Standalone Players
Panny 60" 3D Plasma TC-60ST30
Panny 50" Plasma TC-P50G10
Panny 50" 3D TV TC-P50GT25
Denon AVR-891
Harmoney One Remote
Polk Monitor 70's,Polk CS2, Polk Monitor 40's -
That would be the best bet. I am going to google that one now... -
pics? there's some good ideas herepanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
Wow thanks for all the responses! pic would be great. lots of good ideas!2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
I am also looking to the Ikea model thats a little cheaper
http://www.ikea.com/us/en/catalog/products/501194072 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
Any other suggestions or pics?2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
ttt.2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
Honestly? I just put a rope light behind there. Does the trick. It may have a low-ish WAF, though.
(OH snap, Polk Master.)I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
LED's are too blue in color to be accurate bias lighting. Ideally, you want 6500k color temp bulbs, and a neutral background behind the TV.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Ghetto ambilight:
Buy a cheap LCD 5-7" panel off ebay and feed it the same signal as the TV is getting. Put some kind of diffuser over it, so you don't get distracting motion going on (ie wax paper, smoked glass, etc). Prop it behind the TV facing the wall. Changes color in sync w/ the TV. Did this at my old place w/ a 50" LCD projection & it worked pretty well.
The main problem with the ghetto-ambi was that it transitioned as fast as the signal transitioned, so a sudden change to a dark screen and it'd be gone. Ambilight is more averaged and smoothly transitions from one scene to the next.
I'm sure that one could find a video processor for cheap that'd give you the same end result (only has to be NTSC and doesn't matter if it totally fuzzes up the signal), but I never got around to sorting that out.
Other ideas here:
http://www.polkaudio.com/forums/showthread.php?t=70209Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
The Cinemaquest Ideal Lume is only $59 bucks, and comes with a spare lamp.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
