Ambient light options?
themuskr
themuskr Posts: 149
edited February 2010 in Electronics
Hey all, I was just wondering if there are any cool ways to create some ambient light around my TV. i have seen some behind tv lighting systems, but i was just wondering what others have done.
Sorry if this is in the wrong forum.
thanks-
2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
Pioneer Elite vsx-40
BJC cable
Post edited by themuskr on
  • adabro
    adabro Posts: 212
    Ikea has Dioder LEDs that look good - check out DH4645's set up in the system showcase...
  • steveinaz
    steveinaz Posts: 19,545
    I use a Cinema Quest "Ideal Lume" 6500 kelvin lamp. Makes quite a difference, especially at night.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    A blacklight on either side has always done the trick for me.
    I've also got a blacklight mounted behind each of my speakers. Makes for some great ambiance, when mixed with my numerous posters.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • halo71
    halo71 Posts: 4,631
    For some reason, I am hearing **** music in my mind reading this. :D
    --Gary--
  • kuntasensei
    kuntasensei Posts: 3,263
    I had an Idealume behind my old RPTV, but it didn't work well with my projector screen when I stepped up. I snagged a couple of little LED accent lights from Home Depot and stuck them to the back of my armoires with double-sided tape so that they light up the walls to the sides of the screen. Works quite well, and was cheap.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • grif32
    grif32 Posts: 267
    (3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
    (2) Panny DMPBDT110 3D Standalone Players
    Panny 60" 3D Plasma TC-60ST30
    Panny 50" Plasma TC-P50G10
    Panny 50" 3D TV TC-P50GT25
    Denon AVR-891
    Harmoney One Remote
    Polk Monitor 70's,Polk CS2, Polk Monitor 40's
  • Conradicles
    Conradicles Posts: 6,343
    steveinaz wrote: »
    That would be the best bet. I am going to google that one now...
  • superjunior
    superjunior Posts: 1,632
    pics? there's some good ideas here
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • themuskr
    themuskr Posts: 149
    Wow thanks for all the responses! pic would be great. lots of good ideas!
    1 Mirage OMD-C1
    4 Mirage nanosat MX
    Mirage MM-6
    Def Tech Prosub 100
    BJC cable
  • themuskr
    themuskr Posts: 149
    1 Mirage OMD-C1
    4 Mirage nanosat MX
    Mirage MM-6
    Def Tech Prosub 100
    BJC cable
  • themuskr
    themuskr Posts: 149
    I am also looking to the Ikea model thats a little cheaper
    http://www.ikea.com/us/en/catalog/products/50119407
    1 Mirage OMD-C1
    4 Mirage nanosat MX
    Mirage MM-6
    Def Tech Prosub 100
    BJC cable
  • themuskr
    themuskr Posts: 149
    Any other suggestions or pics?
    1 Mirage OMD-C1
    4 Mirage nanosat MX
    Mirage MM-6
    Def Tech Prosub 100
    BJC cable
  • themuskr
    themuskr Posts: 149
    ttt.
    1 Mirage OMD-C1
    4 Mirage nanosat MX
    Mirage MM-6
    Def Tech Prosub 100
    BJC cable
  • concealer404
    concealer404 Posts: 7,440
    Honestly? I just put a rope light behind there. Does the trick. It may have a low-ish WAF, though.
    (OH snap, Polk Master.)
  • steveinaz
    LED's are too blue in color to be accurate bias lighting. Ideally, you want 6500k color temp bulbs, and a neutral background behind the TV.
  • unc2701
    unc2701 Posts: 3,587
    Ghetto ambilight:
    Buy a cheap LCD 5-7" panel off ebay and feed it the same signal as the TV is getting. Put some kind of diffuser over it, so you don't get distracting motion going on (ie wax paper, smoked glass, etc). Prop it behind the TV facing the wall. Changes color in sync w/ the TV. Did this at my old place w/ a 50" LCD projection & it worked pretty well.
    The main problem with the ghetto-ambi was that it transitioned as fast as the signal transitioned, so a sudden change to a dark screen and it'd be gone. Ambilight is more averaged and smoothly transitions from one scene to the next.
    I'm sure that one could find a video processor for cheap that'd give you the same end result (only has to be NTSC and doesn't matter if it totally fuzzes up the signal), but I never got around to sorting that out.
    Other ideas here:
    http://www.polkaudio.com/forums/showthread.php?t=70209
    Backburner:Krell KAV-300i
  • steveinaz
    The Cinemaquest Ideal Lume is only $59 bucks, and comes with a spare lamp.
