CSi5 mount recommendation
Right now my Center is below my TV, however it's off-centered. During a movie, dialogues are very noticeable to me, to be one-sided but not my wife
. So I've been trying to find some kind of mount that I can buy or DIY-build. Please keep in mind am not much of a carpenter
I'm thinking of it directly-mount onto the TV, if not; wall-mount will be my last resort.
Any ideas? Thanks. :cool:
Frt: Polk RTi10
Ctr: CSi5
Surr: Monitor60
Sub: SVS PB12-NSD
Yamaha RX-V3900
Samsung BDP-1600
Ctr: CSi5
Surr: Monitor60
Sub: SVS PB12-NSD
Yamaha RX-V3900
Samsung BDP-1600
Post edited by Kong911 on
Is your center channel on a some sort of a entertainment center shelf below your TV? Is your TV a flat panel? Is it in the same entertainment center or mounted on the wall? I am trying to visualize what your setup is currently.
Yes to all the questions, and the TV is rested on top of the entertainment centre. Basically, I have a 3-tiers shelves w/ Receiver and Centre channel at bottom; Blu-ray and Wii in the middle; and TV on top shelf.
FYI I cannot fit my centre to middle shelf, 'cause the height is too low. Didn't realize how big this baby is.
Frt: Polk RTi10
Ctr: CSi5
Surr: Monitor60
Sub: SVS PB12-NSD
Yamaha RX-V3900
Samsung BDP-1600 -
I used two shelf brackets. Mounted them on the wall behind and level with the top of TV. Painted them black to match.
Thank rpal. Any other suggestion other than wall mount? i preferred to mount onto the TV first if I'm able to.Frt: Polk RTi10
Ctr: CSi5
Surr: Monitor60
Sub: SVS PB12-NSD
Yamaha RX-V3900
Samsung BDP-1600
