CSi5 mount recommendation
Kong911
Kong911 Posts: 15
edited February 2010 in Speakers
Right now my Center is below my TV, however it's off-centered. During a movie, dialogues are very noticeable to me, to be one-sided but not my wife :p. So I've been trying to find some kind of mount that I can buy or DIY-build. Please keep in mind am not much of a carpenter :D.
I'm thinking of it directly-mount onto the TV, if not; wall-mount will be my last resort.
Any ideas? Thanks. :cool:
Frt: Polk RTi10
Ctr: CSi5
Surr: Monitor60
Sub: SVS PB12-NSD
Yamaha RX-V3900
Samsung BDP-1600
Post edited by Kong911 on
  • Medjai
    Medjai Posts: 7
    Is your center channel on a some sort of a entertainment center shelf below your TV? Is your TV a flat panel? Is it in the same entertainment center or mounted on the wall? I am trying to visualize what your setup is currently.
  • Kong911
    Kong911 Posts: 15
    Yes to all the questions, and the TV is rested on top of the entertainment centre. Basically, I have a 3-tiers shelves w/ Receiver and Centre channel at bottom; Blu-ray and Wii in the middle; and TV on top shelf.
    FYI I cannot fit my centre to middle shelf, 'cause the height is too low. Didn't realize how big this baby is. :)
    Frt: Polk RTi10
    Ctr: CSi5
    Surr: Monitor60
    Sub: SVS PB12-NSD
    Yamaha RX-V3900
    Samsung BDP-1600
  • rpalme1
    rpalme1 Posts: 34
    I used two shelf brackets. Mounted them on the wall behind and level with the top of TV. Painted them black to match.
  • Kong911
    Kong911 Posts: 15
    Thank rpal. Any other suggestion other than wall mount? i preferred to mount onto the TV first if I'm able to.
    Frt: Polk RTi10
    Ctr: CSi5
    Surr: Monitor60
    Sub: SVS PB12-NSD
    Yamaha RX-V3900
    Samsung BDP-1600
