TV makes me see Red!
Mike Kozak
I will have to put my purchase of a new AV Receiver on hold.....I cam home from work, turned on my Samsung 50" DLP and saw red. Any suggestions on a 50 or 52" TV? I am thinking LCD at this point.
Post edited by Mike Kozak on
Look at the Samsungs...great pictures, and (at my local frys at least) they come with a free Samsung blu-ray player."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
Any LED's in your price range?
Checked on cost of replacing your display lamp?--Gary--
Well I paid almost 1400.00 for My Samsung DLP 3 years ago, so I am thinking around 1200 should get me a decent TV
Out of curiosity, what exactly do you mean that you saw red? Is it a lamp issue? If so, you could replace it for much cheaper than the cost of a new TV (around $100 for the part and 10 minutes of labor). It was a snap to replace the lamp on my mitsubishi DLP.
Agreed; DLP technology was great at the time, but long term the lamps have issues. I would bet that it is simply a lamp issue, in which case it is as easy as changing a headlight in your car. Look around for a lamp - for $100 bucks or a little more it might be worth it to try rather than buying a whole new tv.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
I had the red color chip replaced last July, the cost was 230.00 for the labor/anaged to get Samsung to pay for the part. The tech did leave me the green and blue chips (85.00 each, so maybe I eill call him up to see if he can fix it.
Ok, so it sounds like a color wheel issue. It's a bit more difficult to replace, but isn't that tough. Then again, I think a new color wheel is in the $250 range (not positive). Once you start spending that kind of money, you might as well think about a new television. But, it's up to you.
I take that back. partstore.com has color wheels for samsungs in the $100 range. http://www.partstore.com/Content/LandingPages/Color-wheels.aspx -
well considering that I haget a new tv and be done with it.ve spent 230 on the fix last year I am going to buy a new tv
Mike Kozak wrote: »well considering that I haget a new tv and be done with it.ve spent 230 on the fix last year I am going to buy a new tv
Thats always been my complaint with DLP an older projection LCD's.
Dump the DLP, new tv's are pretty cheap now anyways.HT SYSTEM-
lsi 9's -
I've got a 1080P 50" Samsung plasma that has awesome picture been zero trouble and can probably be found in the States for less than $900. Just before I got this one I had the 50" Panasonic but took it back because of too much grain and very high judder (like motion blur but caused by video processor). Totally pleased with Sammy.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Should I go with LCD or Plasma? I thought LCDs look better.
Personally I would go with Plasma. According to the "numbers" plasmas are capable of better contrast ratios, deeper blacks, and pretty much better all around picture. Better viewing angles, less power consumption (I think) more affordable large screen units, and generally cost less. There was/still is a problem with burn in, but there is improvements being made in that area with the newer sets and anti burn in thingy majigys. Plasmas can sometimes be a hassle to set up in bright rooms, and have problems with glare, but IMHO Plasma is the way to go. If/when I ever upgrade my TV it will be to a plasma.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Mike Kozak wrote: »Should I go with LCD or Plasma? I thought LCDs look better.
Plasma is the better TV. LCD's will look good in stores because stores have the perfect set-up for LCD's not so much Plasma's.
Plasma's will shine once you get them set up in your home. So much more pop then LCD at night. Blacker blacks, better viewing angles etc..
If you have a very bright room and mostly watch tv during the day then LCD would be the way to go due to glare on a plasma which is not horrible but lcd is a little better.
LED = overpriced LCD tv's. They have a nice Picture but plasma will give you same if not a better picture at a fraction of the cost IMHO. Plus if you move just one cushion left or right with LED/LCD Tv's your picture will lose color.
If you watch mostly at night then Plasma is the way to go.
$1200 will get you a very nice Plasma
But it comes down to your eyes. Go to a few stores and mess around with them.
Remember LCD's in stores are set to Vivid and the lighting make them look very bright.
Plasma's will be turned down to make very dim.
Burn-in is a thing of the past. You might see IR for the first 200 hrs but that will go away.(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
(2) Panny DMPBDT110 3D Standalone Players
Panny 60" 3D Plasma TC-60ST30
Panny 50" Plasma TC-P50G10
Panny 50" 3D TV TC-P50GT25
Denon AVR-891
Harmoney One Remote
Polk Monitor 70's,Polk CS2, Polk Monitor 40's -
I used to have a 52" Mitsu DLP, until I just recently purchased a 40" Sammy LCD. It does obviously have a smaller display but I'm way happier with the sammy. I was under the impression that plasmas do cost more to run then plasma, but I could be wrong.T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W -
FWIW I love my Panny plasma.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Plasma's may look nice, but wait till it craps out in 2 years and the repair bill is almost as much as a new set."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
All electronics have a lifespan Face, and from what I have read (and a few friends that have Plasma sets) there have been some advances in the Plasma TV's to increase their life expectancy. While I don't disagree that a replacement/fix would probably be about as much as a new set, lets face it they just don't make em like they used to.
-JeffHT Rig
Blu-Ray- 80 GB PS3
You have ZERO clue what you are talking about. Tell me why I have had my 42" Panny Plasma for over 7 years now and still puts out a beautiful PQ if they crap out in 2 years :rolleyes:
Please do not spread FUD when you have no idea what you are talking about.
Today's Plasma will average around 22 - 30 years. They have a rated life of 100,000 until 1/2 life.
They will last just as long or longer then an lcd.
I am curious as to what you think would make the plasma crap out and cost as much as a new set???(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
Denon AVR-891
Harmoney One Remote
Did I say EVERY plasma will die prematurely?
That information is from my neighbor owns a TV repair shop, I believe he has a better idea than you do."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
You can get an awesome 50" Plasma like mine for $959 now at BB or HHgregg.~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox -
LMAO... Like I stated please tell me what about a plasma will cause it to die and make it the cost of a new set?? I will wait until you run over to your neighbor's TV repair shop and get the answer :rolleyes:
And you stated that PLASMA'S look nice but wait until it craps out in 2 years. Could it happen sure just like it could for DLP and LCD.
Failure rate is something like less then 3% for TV's including Plasma's
Believe what you like but please do not come in here spreading FUD about plasma's.
I have installed many many many Plasma's over a 3 - 4 years span and NOT ONE has died or needed repair.(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
Denon AVR-891
Harmoney One Remote
Agree, Best Buy also had the Tc-p50X1 which is only 720P but has amazing blacks and an amazing picture for $699 which a steal for this TV. This TV will compare to many LCD's twice it's price.
OP has a lot of options. He can wait until the new TV's come out or head to a store a tweak the LCD's and Plasma's they have.
It's the OP's eyes and what he likes.
Good luck either way.(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
Denon AVR-891
Harmoney One Remote
Although my Samsung HL-S5086W 50" has been great, it will be replaced with a plasma and moved to the 70's mancave soon.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
My Manager here at work said he could sell me his "used" TV. He said he has only used it for the past 3 months. http://www.amazon.com/Samsung-LN52A750-52-Inch-1080p-Touch/dp/B001418WF4/ref=sr_1_2?ie=UTF8&s=electronics&qid=1265735576&sr=8-2
Mike Kozak wrote: »My Manager here at work said he could sell me his "used" TV. He said he has only used it for the past 3 months. http://www.amazon.com/Samsung-LN52A750-52-Inch-1080p-Touch/dp/B001418WF4/ref=sr_1_2?ie=UTF8&s=electronics&qid=1265735576&sr=8-2
Nice TV. It is discontinued. How much is he willing to sell it to you for? -
We have not talked price, so I have no idea how much he would let it go for. I will keep the forum posted. No pun intended.
I ahve offered 1200.00 for it, is that a good deal?
No more tv problems. The issue was with the Direct TV DVR Box Once I reset it all is fine again
That is stupid Face and you should be banned.
