lsi 15 tweeter not working
slammerag03
i recently purchased lsi15 on ebay. when i received them both bases were broken by ups, otherwise they were mint. when i hooked them up, the tweeters didnt work on either speaker. i hooked the leads directly to the tweeter with no bass and a low volume level and they worked. is this a crossover problem? does it seem odd that both did not work?
My rig: LSI 15 fronts, LSI C center, LSI 7 rear, PSW1000 w/ elemental design amp
Post edited by slammerag03 on
Pull the crossover and look for any obvious damage. It's attached to the back of the binding post cup."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
are the gold jumpers connected. i bet that they were using the lsi's bi-amped. other wise i would think the XO is smoked.
i did not see any obvious damage. im trying to get a price for the x-over and have ups pay but polk is dealing with the blizzard.My rig: LSI 15 fronts, LSI C center, LSI 7 rear, PSW1000 w/ elemental design amp
yes they were in place. can the x-overs be damaged by the speakers being dropped?My rig: LSI 15 fronts, LSI C center, LSI 7 rear, PSW1000 w/ elemental design amp
not a XO expert but i highly doubt that. they are pretty well contained inside the speaker. i would still take a look. did the seller state they were working prior to shipping??
i had a crazy party and smoked ( literally ) the XO from too much volume for too long. luckly the place i bought them from replaced them for me ( lesson learned )
make sure the binding posts are screwed tight to hold the jumpers. -
anybody have any idea what the tweeters cost? im going to get all i can out of ups. the previous owner said they worked fine.My rig: LSI 15 fronts, LSI C center, LSI 7 rear, PSW1000 w/ elemental design amp
u said that they worked - i wouldn't replace them until you check the XO.
is there any way to test the crossover? i have a fluke multi-meter and a decent electrical understandingMy rig: LSI 15 fronts, LSI C center, LSI 7 rear, PSW1000 w/ elemental design amp
can't help you on that.
BTW welcome to Club Polk -
Absolutely. Check for cracked boards, loose/broken solder joints. Also check for loose connections at the board, binding posts and the tweeters/drivers.
That said, what you should really do is have UPS total the speakers and get new ones.Political Correctness'.........defined
President of Club Polk -
Polk CS can tell you..."I Think" they are around $70ea, but I am not sure.slammerag03 wrote: »anybody have any idea what the tweeters cost? im going to get all i can out of ups. the previous owner said they worked fine.
be sure and mention you are a club polk member for a slight discount.
If the tweeters work though - why are you planning to replace them?
Did you pull the crossover and does everything look good there? Snap a few pics of what the crossovers look like and we will try and give you an idea of what could be the problem.
i tested continuity across the resistors and 1 was bad in each crossover. when i jumped across the bad res. the tweeter worked.
the speakers were insured for way less than replacement value so i am limited to what i can get from ups. unfortunately while disconnecting the leads i broke a spade on the tweeter.My rig: LSI 15 fronts, LSI C center, LSI 7 rear, PSW1000 w/ elemental design amp -
That high frequency circuit resistor is a known issue. I'd bet they were bad before shipping.
Why under insured? Were they in the factory cartons?Political Correctness'.........defined
Here's what you need, two of these: http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=005-2
They'll also be an upgrade to stock."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
i replaced the 5ohm reisitors and both speakers work great. thanks for the helpMy rig: LSI 15 fronts, LSI C center, LSI 7 rear, PSW1000 w/ elemental design amp
