lsi 15 tweeter not working
slammerag03
slammerag03 Posts: 11
edited February 2010 in Troubleshooting
i recently purchased lsi15 on ebay. when i received them both bases were broken by ups, otherwise they were mint. when i hooked them up, the tweeters didnt work on either speaker. i hooked the leads directly to the tweeter with no bass and a low volume level and they worked. is this a crossover problem? does it seem odd that both did not work?
My rig: LSI 15 fronts, LSI C center, LSI 7 rear, PSW1000 w/ elemental design amp
Post edited by slammerag03 on
  • Face
    Face Posts: 14,340
    Pull the crossover and look for any obvious damage. It's attached to the back of the binding post cup.
  • Vette C6.r
    Vette C6.r Posts: 1,560
    are the gold jumpers connected. i bet that they were using the lsi's bi-amped. other wise i would think the XO is smoked.
  • slammerag03
    i did not see any obvious damage. im trying to get a price for the x-over and have ups pay but polk is dealing with the blizzard.
  • slammerag03
    yes they were in place. can the x-overs be damaged by the speakers being dropped?
  • Vette C6.r
    not a XO expert but i highly doubt that. they are pretty well contained inside the speaker. i would still take a look. did the seller state they were working prior to shipping??
    i had a crazy party and smoked ( literally ) the XO from too much volume for too long. luckly the place i bought them from replaced them for me ( lesson learned )
    make sure the binding posts are screwed tight to hold the jumpers.
  • slammerag03
    anybody have any idea what the tweeters cost? im going to get all i can out of ups. the previous owner said they worked fine.
  • Vette C6.r
    u said that they worked - i wouldn't replace them until you check the XO.
  • slammerag03
    is there any way to test the crossover? i have a fluke multi-meter and a decent electrical understanding
  • Vette C6.r
    can't help you on that.
    BTW welcome to Club Polk
    F1nut Posts: 51,689
    Absolutely. Check for cracked boards, loose/broken solder joints. Also check for loose connections at the board, binding posts and the tweeters/drivers.
    That said, what you should really do is have UPS total the speakers and get new ones.
  • kcoc321
    kcoc321 Posts: 1,788
    Polk CS can tell you..."I Think" they are around $70ea, but I am not sure.
  • McLoki
    McLoki Posts: 5,231
    be sure and mention you are a club polk member for a slight discount.
    If the tweeters work though - why are you planning to replace them?
    Did you pull the crossover and does everything look good there? Snap a few pics of what the crossovers look like and we will try and give you an idea of what could be the problem.
    Michael
  • slammerag03
    i tested continuity across the resistors and 1 was bad in each crossover. when i jumped across the bad res. the tweeter worked.
    the speakers were insured for way less than replacement value so i am limited to what i can get from ups. unfortunately while disconnecting the leads i broke a spade on the tweeter.
    F1nut Posts: 51,689
    That high frequency circuit resistor is a known issue. I'd bet they were bad before shipping.
    Why under insured? Were they in the factory cartons?
  • Face
    Face Posts: 14,340
    Here's what you need, two of these: http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=005-2
    They'll also be an upgrade to stock.
  • slammerag03
    i replaced the 5ohm reisitors and both speakers work great. thanks for the help
