Stands for FXi30??
brentman0110
brentman0110 Posts: 87
edited October 2003 in Speakers
What are the best stands for the FXi30's for the money?? Used for rear surrounds.
Post edited by brentman0110 on
  • donahue
    donahue Posts: 125
    edited October 2003
    I've seen this thread somewhere in the forum before. I believe that the consensus was that there are no stands that would raise the FXi30s to the height that they need to be at (2-3 feet above listening position). I too, have the FXi30s and I'm planning to mount them on the wall (as soon as I can squeeze myself into the crawlspace under the room.
    Ray
  • dorokusai
    dorokusai Posts: 25,633
    edited October 2003
    Don - If we never hear from you again, we will alert the authorities as to your location. :D
    I agree, they should be high on the wall. All you need is a screw.
  • kberg
    kberg Posts: 974
    edited October 2003
    I have the Sanus 24" stands from Crutchfield. They put the tweeter at ear level, but some day I will wall-mount them 2-3 feet above the listening position, but they sound great even now.
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
