75 ohm coaxial cable
NeilGabriel
NeilGabriel Posts: 1,487
Can anyone tell me what a 75 ohm coaxial plug pin cable is?
Post edited by NeilGabriel on
  • Jed Leland
    Jed Leland Posts: 182
    edited February 2010
    Hello,
    Are you looking for an RCA plug that will go on the end of a coaxial cable and have a characteristic impedance of 75 ohms? Not quite sure what you're looking for?
    Cheers, Ken
  • kaiserkreb
    kaiserkreb Posts: 16
    Isn't that what you plug your TV into an antenna with?
  • ShinAce
    ShinAce Posts: 1,194
    Are you reading the bluejeans descriptions?
    If yes, they're using plug pin to refer to an RCA connector. A 75 ohm cable with rca connectors on it would be a digital audio cable. SPDIF!
    Honestly, you're question is not clear. What are you trying to do?
  • Jed Leland
    Hello,
    If it is a true digital cable, the RCA plug itself would have to have a 75 ohm impedance as well as the cable. The dielectric used in the RCA plug would have to have a 75 ohm impedance at RF.
    Cheers, Ken
  • zingo
    zingo Posts: 11,258
    Here is RCA plug (can be 75ohm) on the left and BNC (more standard 75ohm) on the right.
  • NeilGabriel
    ShinAce wrote: »
    I think the last picture on the left is what I am talking about. This is the EXACT language from the B&K manual for connecting the AVR monitor out to the monitor so I can get the on screen set up menu. It says that this is the only output that will work...not S-video, not component...
    sorry for lack of clarity, but that is the phrase that is used...it sounds like a traditional video cable, like for cable tv, but with an RCA plug on the end...and not a composite video connector...
