75 ohm coaxial cable
NeilGabriel
Can anyone tell me what a 75 ohm coaxial plug pin cable is?
Post edited by NeilGabriel on
Hello,
Are you looking for an RCA plug that will go on the end of a coaxial cable and have a characteristic impedance of 75 ohms? Not quite sure what you're looking for?
Cheers, Ken -
Isn't that what you plug your TV into an antenna with?
Are you reading the bluejeans descriptions?
If yes, they're using plug pin to refer to an RCA connector. A 75 ohm cable with rca connectors on it would be a digital audio cable. SPDIF!
Honestly, you're question is not clear. What are you trying to do? -
Hello,
If it is a true digital cable, the RCA plug itself would have to have a 75 ohm impedance as well as the cable. The dielectric used in the RCA plug would have to have a 75 ohm impedance at RF.
Cheers, Ken -
Here is RCA plug (can be 75ohm) on the left and BNC (more standard 75ohm) on the right.
I think the last picture on the left is what I am talking about. This is the EXACT language from the B&K manual for connecting the AVR monitor out to the monitor so I can get the on screen set up menu. It says that this is the only output that will work...not S-video, not component...
sorry for lack of clarity, but that is the phrase that is used...it sounds like a traditional video cable, like for cable tv, but with an RCA plug on the end...and not a composite video connector...
