TT upgrades
kevhed72
My budget is tight nowadays, but I have been considering these upgrades to my current turntable and wondering how much improvement each would yield before I put any more money into a very modest Yamaha TT:
1. Upgrading the stock power cord (which is the thinnest power cord I have ever seen) with a PS Audio cord, which I believe needs to have the reversible C-7 plug which goes to the TT(?)
2. Record clamp (not weight), which can be had off Music Direct for under 50.00
3. New turntable mat (I am skeptical on this one but thought I would ask)
Any advice is appreciated on 1 to 3 above...
Post edited by kevhed72 on
Try a Herbie's mat. 90-day no-risk trial. If not satisfied, simply return any Herbie's Audio Lab product within 90 days for a complete refund.
http://herbiesaudiolab.home.att.net/ttmat.htm
Turntables with thin platters can ring, so I'd stay with a mat that decouples the LP from the platter. As Herbie's mentions in his Way Excellent II ad; Records are thoroughly decoupled from unwanted platter vibration.
A properly designed clamp will hold an LP very tightly against the mat and platter. I find this effective on damped platters or platters with mass, but not on thin platters. As usual, yours or others mileage may vary.
EDIT: Which Yamaha table do you have? I've got an old Yamaha YP-D10 in the basement rig.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
kevhed72 the best and most dramatic improvement will be realised with a record clamp, preferably a reflex clamp. Such as this;
http://store.acousticsounds.com/d/36249/Clearaudio-Twister_Clamp-Record_Mats_and_Clamps
They are back ordered at Acoustic Sounds but you can get it at Needledoctor or Audio Adviser.
The next best improvement will come with a good mat like the Herbies.
Upgrading the power cord on a TT will have the least effect on the SQ but a worthwhile improvement down the line as it will decrease motor noise. -
I would reccomend Herbie's mat. I use it on my Pro-Ject 6.9 and on my Technics SL-BD27 which is a budget table with a very light platter I use for vinyl ripping. With Herbie's mat on it the light aluminum platter is dead silent.
I am in no way associated with Herbie's by the way.
The $50.00 clamp from Music Direct is a bargain and will really help bring out bass and detail. Combine that with the mat and you've got a huge upgrade. If you are on a really tight budget I'd go in this order:
1. Clamp
2. Mat
3. Power cord upgradeSDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I was a nonbeliever in the mat as well. Half my reason for getting Herbie's mat was to eliminate the dust issue on the felt mat. Just got mine the other day - it most definitely tightened things up.
No need for A/Bing etc. The difference was clear immediately. (pun intended)Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
I want a herbie.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
SCompRacer wrote: »
I have a Yamaha 400, which I remember was on the lower end of TT's, which I bought around 18 yrs ago(?)
Thanks everyone for the input...I'll go with the clamp and mat first, and then maybe the power cord if I can scoop up a deal off Ebay.
