shipping box
dant
dant Posts: 8
edited October 2003 in Troubleshooting
______________
Post edited by dant on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited October 2003
    Order one from Polk, duh. ;)
  • fox
    fox Posts: 62
    edited October 2003
    My receiver did the same thing when you say it went into a protection mode. The problem was the wire connection to the speaker was not as good as it needed to be. Check your speaker wire connections to the CC, and try again. It is just possible that the receiver is detecting a short in the connection to the speaker and will not allow the unit to play sound. At least try it and see.
  • faster100
    faster100 Posts: 6,124
    edited October 2003
    let me check my stock of extra boxes, that i no longer have speakers for, psw404,rti28, r15, nope no extra Csi40 box ... :D
    I really do have those extra boxes though..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • acdds
    acdds Posts: 253
    edited October 2003
    This may sound stupid but I would call around to the local Circuit City stores and ask if they have an extra one (maybe from one of their displays). Or you could go and by a new Csi40 at CC then return it without the box. You would still get a full refund.
    Receiver = Denon AVR-3803
    DVD = Denon DV-2900
    Fronts = SDA SRS 2.3TL's
    (Carver m1.5t)
    Center = CSi40
    Side surrounds = Fxi30's
    Sony 12" sub
    TV = Hitachi 57F500
    Bedroom rig:
    Pioneer SX-1050 receiver
    Rti38's
