TELEFUNKEN ribbed or smooth plates 12AX7
Toolfan66
What the hell is the difference?;)
Will it really matter which ones I use in my phono pre? Thought I should ask before I pull the trigger on a set.
Thanks Fellas.
Thanks Fellas.
Post edited by Toolfan66 on
Bump?
I've always had an affinity for the smooth plate tele's. YMMVJC approves....he told me so. (F-1 nut)
Difference would be the lower amount of money left in your wallet if you went with ribbed plates;).
I haven't heard the ribbed plates but have experience with the smooth plate. I like the sound but I can't believe how much they're going for. IMO the Ei copy of the smooth plate is very nice and a good substitute if you don't want to spend a lot of money. -
DeletedSystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub
Ask Brent Jesse.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
