TELEFUNKEN ribbed or smooth plates 12AX7
Toolfan66
Toolfan66 Posts: 18,066
edited February 2010 in Electronics
What the hell is the difference?;)
Will it really matter which ones I use in my phono pre? Thought I should ask before I pull the trigger on a set.
Thanks Fellas.
Post edited by Toolfan66 on
  • george daniel
    george daniel Posts: 12,096
    I've always had an affinity for the smooth plate tele's. YMMV
  • organ
    organ Posts: 4,969
    Difference would be the lower amount of money left in your wallet if you went with ribbed plates;).
    I haven't heard the ribbed plates but have experience with the smooth plate. I like the sound but I can't believe how much they're going for. IMO the Ei copy of the smooth plate is very nice and a good substitute if you don't want to spend a lot of money.
  • Jetmaker737
    Jetmaker737 Posts: 1,118
    Deleted
  • ben62670
    ben62670 Posts: 15,969
    Ask Brent Jesse.
    Ben
