Will there be any problem using 2 Subs (PSW-505 and Velodyne DPS-12)?
Will there be any problem using 2 Subs (PSW-505 and Velodyne DPS-12) from different manufacturer?
Polk CS20
Polk Monitor 70
Polk Monitor 50
Polk M10
Polk PSW505
Yamaha HTR 6260B
Samsung 46" Series 5
Wish list:
Power Conditioner
Logitech Remote
Polk Monitor 70
Polk Monitor 50
Polk M10
Polk PSW505
Yamaha HTR 6260B
Wish list:
Power Conditioner
Logitech Remote
Post edited by R13 on
PSW505
Driver Complement
Subwoofer 1 - 12" Diameter (30.48cm)
High excursion polymer composite cone with hi roll surround, shielded
Electrical
Overall Frequency Response 23Hz - 160Hz
Lower -3dB Limit 28Hz
Upper -3dB Limit 125Hz
Crossover Variable low pass 60 - 125Hz, 4th order
Inputs Speaker level 5-way binding posts, line level (filtered) and LFE (unfiltered)
Outputs Speaker level
Dimensions
Cabinet Size 16-1/8" H x 15-1/8" W x 18-3/16" D
(40.96cm H x 38.42cm W x 46.20cm D)
Enclosure Type Vented via slot loaded port
Subwoofer Amplifier Specs
Power Output 300 watts Continuous Average Output
Dynamic Power Output 460 watts
DPS 12
Amplifier Cass A/B 400 watts Dinamic/200 watts RMS Power
Woofer 12” forward firing
(9,9” piston diameter)
Voice Coil 2” four layer cooper
Magnet 55 oz
Low Pass Crossover 40Hz – 120 Hz adjustable
(12 dB/octave inicial
48 dB / octave ultimate
Inputs Line level and speaker level
Frequency Responde 25-120 HZ (+/-3dB)
In my opinion will have no problem -
I second that. It may be a little less clean than two identical subs but it will not hurt your equipment and should sound better than just one sub of course. How do you like the dps-12 by the way? I have 2 dps-10s and they are decent, seems like the 12 should hit pretty hard
Its like driving 2 different models of car from diff manf, having exact same features and specs, it will have its own feel, agility, comfort, drivability etc.
I wouldn't do it.. they'll respond differently, i think you'll just end up with muddy, incoherent sound.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
If I had to use two subs, I would use two identical subs
Fronts: Energy RC-70
Center: Energy RC-LCR
Surrounds: Energy Veritas 1.0CM
Subwoofer: SVS PC12-NSD
Receiver: Onkyo TX-SR705
Amplifier: Denon POA-2200 w/ Ben's ICs
Pics of my setup (click me) -
+1, best case scenario when using two subs is to use identical ones. Setting up two subs to play nice together is hard enough with two of the same ones, nevermind using two different ones. It's not impossible, just adds to the degree of difficulty. Welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
I've often thought of running two Boston subs that I have together....but even they are different...one has a coated reinforced fiber cone with a 200 watt BASH amp, the other a polycarbonate--filled cone with a 300 watt class D amp? Both are 12" subs but have very different characteristics.
I haven't tried this yet...but I expect some difficulties with the set up!
Thanks for the reply but I have just started with my set-up and was wonderring what is a MUDDY BASE?Polk CS20
Polk Monitor 70
Polk Monitor 50
Polk M10
Polk PSW505
Yamaha HTR 6260B
Wish list:
Power Conditioner
Logitech Remote
