Maurice - System Showcase
RuSsMaN
RuSsMaN Posts: 17,986
edited October 2003 in Speakers
Couple of questions/ideas on your mains. Can you 'swap' the right main and the lamp on the right? Looks like it might help to balance out the front stage a little bit.
Also, maybe even bring the mains slightly forward of the 'plane' they are on now. They appear to be dead-even with the tv/rack.
How's the rest of the floor in the room? Got an area rug you could use to ease reflections?
Just a couple friendly suggestions, rig looks good. When will the 'punk' be replaced?
Cheers,
Russ
Post edited by RuSsMaN on
  • Maurice
    Maurice Posts: 517
    edited October 2003
    The punk is gone in 2 weeks. The mains are even with the Tv and i can move the lamp. Think that will help. Also, I do have a 9x12 area rug. When I get the new pics up you'll be able to see it. Thanks for the input bro.
    Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
    Polk 70's,40,30's
    Velo DLS 3500 Sub
    JVC 61" HD-ILA
    Sony DA4ES AVR
    Oppo 981 DVD
    Sony CDP-CX235 CD
    Signal Bi-wires
    AR ProII IC's
    VR3 Posts: 29,385
    edited October 2003
    Russ,
    Nice suggestions.
    Maurice,
    Where did you get the 52(?) Foot TV?????
  • Maurice
    Maurice Posts: 517
    edited October 2003
    Vr, I posted a reply but hit the new thread button instead. Rookie mistake. Take a gander at 52 footer.:D
    Polk 70's,40,30's
    Velo DLS 3500 Sub
    JVC 61" HD-ILA
    Sony DA4ES AVR
    Oppo 981 DVD
    Sony CDP-CX235 CD
    Signal Bi-wires
    AR ProII IC's
