Remove PSW 1000 side panels?
john22614
john22614 Posts: 214
edited January 2010 in Speakers
Hey Guys,
I just upgraded my front sound stage from LSI 9's to B&W 800 series monitors in cherry wood. The shade is quite a bit lighter than the darker cherry on my PSW 1000 sub. So, I thinking, just for looks, I would like to remove the side panels from the sub, but only if there is a glossy piano black finish underneath. Does anyone know if that's the case? I know a couple of you have modified the side panels of the LSI floor standers and monitors with much success.
I guess the other option would be to re finish the wood panels in some kind of black stain or paint, but I'm kind of hesitant to try that, especially if there is a glossy finish underneath.
I love the sub, just want it to blend in better visually. Would appreciate any thoughts you might have.
By the way, I love the new speaks. Very sweet.
B&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Monitor Radius 180 surrounds
Audiosource Stereo Amp for surrounds
Denon 2910 Universal DVD/SACD Player
Comcast DVR
Pioneer Elite 42" Plasma 940 HD
Harmony Universal Remote
Blue Jeans interconnects and biwires
Itunes Air Express
Post edited by john22614 on
  • jimmydep
    jimmydep Posts: 1,305
    edited January 2010
    If your speakers are new, just out of the box, the wood might seem light, but Cherry darkens over time, especially if exposed to sunlight. You might want to give it a month or so, before making any changes.
    Jimmy
  • john22614
    edited January 2010
    Thanks Jimmy, but the speakers were already out of box at the dealers for a few months as demos which was great 'cause I got them at a nice discount. They will not get any sun light. The difference in color is substantial, I can't see them ever darkening enough match the sub. Fortunately, the sides are not too noticeable the way I have it set up. I just want to make it perfect. If I can somehow do a good job of making them black, they will blend in with my plasma and electronics and set off nicely with the other speaks.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Comcast DVR
    Itunes Air Express
    treitz3 Posts: 19,992
    edited January 2010
    You could always lightly scuff them, prime them and then paint them a satin finish in black.
  • john22614
    edited January 2010
    Yeah, that's what I'll probably end up doing. Think I'll call Polk on Monday and see if they can describe what's under the panels. If it's not glossy, I'll probably go ahead and paint them, very carefully and with good prep. I really like the piano black. But, the satin finish should look nice too.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Comcast DVR
    Itunes Air Express
