Denon DL-160
Toolfan66
Anybody know the PF setting for this cart. I have it set at 150 on my phono pre but I can't find any info on the PF for this cart.
Thanks.
Thanks.
Post edited by Toolfan66 on
PF? I have the cartridge myself and have never heard that termThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Pico fared
got me on that one Bro... now I will loose sleep tonight until I get an answer.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Did you look at the manual on vinylengine ?
I have a 160 but my cambridge 640p does not have any switches to set.
How do you like the Jolida 9A ?Speakers: SDA-1C (most all the goodies)
Never mind, the manual does not have it.Speakers: SDA-1C (most all the goodies)
The Denon DL-l60 ($115) is a high-output moving-coil cartridge designed to be connected directly to the phono input of any amplifier without using a step-up transformer or head amplifier. The winding resistance of the coils is 160 ohms per channel, but the cartridge load is specified as 47,000 ohms or greater. Like most moving-coil cartridges, the DL-160 does not have a user-replaceable stylus. Its rated output is 1.6 millivolts (mV), and the recommended tracking force is 1.3 to 1.9 grams. The diamond stylus tip has a rectangular cross section and a special elliptical shape.
The DL- 160 is housed in a black, molded-plastic case with an integral hinged stylus guard. The relatively low total cartridge weight of 4.8 grams is within the adjustment range of most tonearms (ours balanced with its counterweight nearly all the way forward). An extra metal weight is supplied that, when mourned between the cartridge and the headshell, will allow it to be balanced in almost any arm. The supplied overhang-adjustment gauge contains a magnifying section for stylus inspection, and a stylus cleaning brush is also supplied.
Hope this helps...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Is it possible to derive the capacitance by the output impedance ?Speakers: SDA-1C (most all the goodies)
I love it. But I would like to do the cap upgrade. -
I am finding 200-280 pf being tossed about but I don't feel those numbers are 100%The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I measured it at 132pF on my DL160 so your 150pF setting is fine.
I seem to recall 150 being the recommended setting but I couldn't tell you where I know that from, however, my Carver C-1 allows for capacitance tuning and I think it worked best on the 100 pf setting when using the mm input but the difference was almost negligible. I have found capacitance tuning to have a bigger effect on moving magnet cartridges.It sounded better in my opinion when using the mc input even though the cartridge is a high output mc.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
TOOLFORLIFEFAN wrote: »I love it. But I would like to do the cap upgrade.
I kinda have the fever to upgrade phono stages and the Jolida is the one I keep coming back to.Speakers: SDA-1C (most all the goodies)
Capcitance loading to an MM cartridge is as important as resistive loading is to MC carts. The closer you can get to the manufacturers recommedation the better it will sound. I'm surprised that most MM phono pre's don't offer a wider selection of cap. settings. My phono pre offers a half dozen settings and custom settings for both resistance & capacitance loading for MC & MMs respectively.
The DL-160 is a high output Moving Coil and does not respond to capacitance variations vary much (in my experiance). I was able with my older AES PH-1 to adust the loading some and it did smooth out the DL160s highs a little with 22,000 ohms as aposed to the normal MM input of 47,000 ohms though the voltage output is correct for a MM input on the pre.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Can't argue with experience.:)
